oil pan rust
Old Mar 21, 2012 | 02:57 PM
satcom40's Avatar
satcom40
oil pan rust
I was under the truck yesterday and notice the Oil pan is getting rusty.
What would be the best way to address this.
Old Mar 21, 2012 | 03:12 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Be very careful.... if just surface rust, wire brush and paint it.... if more, you'll have no choice be replace it. In CT, the salt prob got to it.......probe too far and you'll have an oil leak!
Old Mar 21, 2012 | 04:56 PM
satcom40's Avatar
satcom40
Haven't touch it yet, just looking at what can be done.
Old Mar 21, 2012 | 06:27 PM
69cj's Avatar
69cj
Before painting it use a self etching primer and then paint. Another 10 bucks but worth it in the long run.
Old Mar 21, 2012 | 07:04 PM
BLADE35's Avatar
BLADE35
just painted mine with rubberized undercoat seems to be holding up alot better than staight paint that i tried b4
the best part is the tranny pan is aluminum and nice and easy to get off but the oil pan is a pia and rusts easy
Old Mar 22, 2012 | 08:22 PM
nitrogen's Avatar
nitrogen
POR coating they have an etching primer you can order. their instructions are to remove only loose flakes, etch it then apply coating. very durable/rust resistant
Old Mar 23, 2012 | 09:07 AM
69cj's Avatar
69cj
That product is actually called POR 15. It's an excellant product and actually converts the rust into a protective coating. It's also paintable.
Old Mar 23, 2012 | 12:12 PM
satcom40's Avatar
satcom40
OK Thanks I'll see if I can Fine it.
jdw1
Aug 19, 2010 03:28 PM
Ford Breakdown
Jul 10, 2008 04:13 PM
bridgeman
Oct 8, 2007 10:28 AM
Grunt0311
Apr 13, 2006 09:01 PM
getnbz
Jul 16, 2004 05:43 AM
