PCM ?
Old Mar 15, 2012 | 12:21 PM
emery72's Avatar
emery72
PCM ?
There is a sticker under the hood that appears to be from the dealership. It is between the grill and radiater. It has a hand written PCM # and date. Does anyone know what this means? Was the PCM replaced or reflashed? I haven't crawled under the dash to compare the number to the PCM in the truck. I'm going to do that tonight when I'm under there working on the wiring for my gauges.
Old Mar 15, 2012 | 12:29 PM
BillyBob69's Avatar
BillyBob69
What is the number on it?
Old Mar 15, 2012 | 12:49 PM
emery72's Avatar
emery72
I'm not near my truck to look at it right now, but it says PCM and then has what looks like a PCM number. There is a date as well and it is all hand written on a ford sticker. I stuck in a very boring all day meeting trying to kill time.
Old Mar 15, 2012 | 12:52 PM
BillyBob69's Avatar
BillyBob69
Either way...Make sure it does match the sticker that is actually on the PCM under the dash. I don't have one of those stickers on mine so it could be that yours was replaced some time ago.... question is...for what reason.
I would have a Oasis report pulled on it. Could tell you what was done.
You should be able to get one from a dealer. Used to be a link of where you can get one online but that was looong ago. Not sure if it is still out there.
Old Mar 16, 2012 | 12:58 AM
emery72's Avatar
emery72
Here is a picture of the sticker under the hood.
Here is a picture of the PCM in the truck.
I can't make out what the sticker actually says. I bought a used DP Tuner and want to send it back to get reburned for my truck but don't know what to give them for a PCM number.
Old Mar 16, 2012 | 07:50 AM
Tugly's Avatar
Tugly
[LINK] Here ya go!
Old Mar 16, 2012 | 08:55 AM
BillyBob69's Avatar
BillyBob69
It could be the original was repaired but then later replaced. That is a tough call but I don't think Ford would of left the original sticker on the PCM if they changed the programming. I would go with the sticker on the PCM itself. Usually the safest bet.
Old Mar 16, 2012 | 09:15 AM
dsquared's Avatar
dsquared
If you can find someone with a Predator Tuner, you could hook it up and read the PCM code through the diagnostics. That was what I did when I bought my DP in 2008... I don't know if AE will read it; logic dictates it should.....
Old Mar 16, 2012 | 09:22 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
If you're just getting a chip, the NVK2 code will work. The calibration part number crosses to an MRT2 PCM code.
The PCM hardware doesn't change during a reflash, so a chip for an NVK2 PCM will work just fine.
Old Mar 16, 2012 | 10:13 AM
emery72's Avatar
emery72
Thanks for all the help. I got caught up up in the mystery of why the sticker is there and what it means when all that matters for my needs right now is the NVK2. I am still curious though and might stop by the dealership and see if I can get an Oasis report or if they can give me any information about it.
Old Mar 16, 2012 | 11:18 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Why worry about it?
The factory PCM code is for a 99-00 7.3L auto and the reflashed code is for a 99-00 7.3L auto.
Probably a bored technician who needed an additional 0.4 hours on his time ticket to buy his kids a Tickle-me-Elmo for Christmas back in 2000.
F-250 Super Duty
Aug 18, 2010 11:04 AM
osheam
Computer Chips & Tuners
Apr 23, 2008 01:52 PM
Rino Onir
Nov 10, 2007 11:20 AM
shenders99
Sep 22, 2006 04:15 PM
dusty1
2004 - 2008 F150
Apr 14, 2004 05:24 PM
