Member Build Threads
Old Dec 18, 2015 | 08:02 PM
  #181
mike.rogers's Avatar
mike.rogers
let me crawl under there tomorrow and take a few better pics. I'll look up how to identify the 41 transmission.
Old Dec 18, 2015 | 08:24 PM
  #182
49fordv8f4's Avatar
49fordv8f4
If it is a 4 speed, it will have a PTO port on the passenger side and IIRC the case part number will be 51-7006 for a '41 transmission.
Old Dec 19, 2015 | 12:07 PM
  #183
mike.rogers
i've called around a little this morning and took a couple pics. I'll try to get back under there and scrape off a little mud and muck to locate a few numbers. Here's a couple pics. Did see a plate cover on the passenger side.
Old Dec 19, 2015 | 05:34 PM
  #184
49fordv8f4's Avatar
49fordv8f4
That is definitely a pre '41 T9 4 speed, the integral half bell on the transmission case is another indication. You have to lift the button under the shift **** to shift into reverse. Reverse is toward the passenger side of the cab and back toward the seat.
Old Dec 19, 2015 | 06:23 PM
  #185
mike.rogers
cool should go down the road pretty good then... thanks for the info Mark.
After a long talk today with the older brother looks like I'm gonna try to rebuild the 6 cyl and put her back as close to original or the way she is now that I can.
Old Dec 19, 2015 | 08:08 PM
  #186
49fordv8f4's Avatar
49fordv8f4
The T9 is a spur gear transmission. It is direct drive, 1 to 1 ratio in 4th gear. They are a tough transmissions, double clutching is required. Unless you can learn to shift without the clutch, something I never mastered.
Old Dec 27, 2015 | 01:23 PM
  #187
49f68canadian's Avatar
49f68canadian
49 f68 midway restored
Cab on frame
Rebuilt 239 Flathead
Old Dec 27, 2015 | 02:13 PM
  #188
48 Steel's Avatar
48 Steel
Welcome to FTE Mike. You've got a great builder it looks like it is in great shape. I'm on a few forums but FTE is the best.
Old Dec 27, 2015 | 04:37 PM
  #189
harleymsn's Avatar
harleymsn
Cab on frame
Nice looking work there so far. Welcome to FTE.
When you get a chance, start your own build thread and post a link to it here.
Old Jan 12, 2016 | 04:49 PM
  #190
MIBill's Avatar
MIBill
1955 F 100 R
1955 Ford F-100 R
Project I bought already started with an alien 1979 Nova or Camaro front clip, 350 chevy engine, Edelbrock intake, TH350 trans. Chevy 12 bolt diff. I need to come up with a driveshaft, steering column, wheel, brake proportioning valve (1977 corvette style Master cyl. on firewall, etc.
Old Jan 12, 2016 | 04:55 PM
  #191
MIBill's Avatar
MIBill
I have a second 55 f100 project truck and a 55 f250 parts truck. if interested I have a 60 cyl engine, a 3 speed and a 55 4 speed trans, Y block V8 and 6 cyl manifolds and a 1960 marine Y block engine complete.
Old Jan 18, 2016 | 02:29 PM
  #192
BarryBrothersRacing's Avatar
BarryBrothersRacing
1953 F100 (S)
https://www.ford-trucks.com/forums/1416281-bbr-1953-f100-build.html
Old Jan 27, 2016 | 11:09 PM
  #193
CaptPayne's Avatar
CaptPayne
'51 F5 Marmon Herrington 4x4
never got around to putting a link for my build up here.
Working truck restoration for working around the farm and driving into town.
https://www.ford-trucks.com/forums/1...arm-resto.html
Old Jan 28, 2016 | 09:05 PM
  #194
killjoybjg's Avatar
killjoybjg
1948 F1 Jeepers Creepers (D)
https://www.ford-trucks.com/forums/1...-creepers.html
Old Apr 6, 2016 | 11:06 PM
  #195
Bessie's Avatar
Bessie
54 F100 Fordomatic (O)
https://www.ford-trucks.com/forums/1...ld-thread.html
