48 F1 Jeepers Creepers
Old 01-28-2016, 08:55 PM
killjoybjg's Avatar
killjoybjg
killjoybjg is offline
killjoybjg is starting off with a positive reputation.
This is my 1948 F1 that has a 52 cab. it has been a year and a half long process to this point, but thanks to all these threads and other builds on this site it is slowly becoming closer to reality. Original 59AB flathead being restored currently and all other work being done by myself with little help from friends and family. Any comments or help is greatly appreciated!
Old 01-28-2016, 09:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
WOW!! Great pictures! What's your truck's VIN? It must be a very early '48?
It's usually considered a bad idea to hold the 59 series engines on a stand by their bellhousings, they are not meant to support the engine's weight.
I envy your "workshop"!
Old 01-29-2016, 06:57 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is online now
GreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to all
Really nice work!
Old 01-29-2016, 07:22 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is online now
FortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud of
I'm very impressed with your approach and abilities. Looks like a great build. What are your plans for the sheetmetal - and the very cool door art?
Old 01-29-2016, 08:22 AM
r_reed's Avatar
r_reed
r_reed is offline
r_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to beholdr_reed is a splendid one to behold
thanks for all the great pics. esp like the machine work. looks like a great build you have going.
Old 01-29-2016, 10:37 AM
killjoybjg's Avatar
killjoybjg
Thank you I'm not exactly sure on the vin to tell you the truth. I have ideas for additional support for the motor, gonna try to keep it original as possible when it comes to that try to hide a few mounts elsewhere.
Old 01-29-2016, 10:41 AM
killjoybjg's Avatar
killjoybjg
All the sheet metal is gonna be left alone fore now, I have no plans to fix any of it whatsoever. Im gonna expose the door logos a little more and keep them original as possible FortyNiner. Our local speed shop has done all the rest work, they have bored it .080 over crank is .030 it has a 1/4 race cam in it done by Schneider, Isky adjustable lifters all stainless valves, to say all this was expensive is an understatement, but i wanted to stay original and true to the truck and I love the sound of a Flathead.
Old 01-29-2016, 12:16 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Originally Posted by killjoybjg View Post
Thank you I'm not exactly sure on the vin to tell you the truth..
The VIN is exposed in this pic, on the left frame rail in front of your suspension hat. Since it starts with 87HY, that chassis originally housed a flat 6 engine. There's a tag on your firewall that may have a matching number. I would be suspicious of any claims the 59A engine was original to the truck. The 8BA engine was used in US production trucks in '48.
Either way, you've got a very cool project going.
Old 01-29-2016, 12:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Wayne, I think it has been "authoritatively" confirmed on the Barn that very early 48's came with the 59-series engine, just using up inventory. Who knows, really?
Killjoy, I meant while the engine is on the stand, you should not rely on holding it by the bellhousing.
Old 01-29-2016, 12:56 PM
killjoybjg's Avatar
killjoybjg
We actually have it supported from the front mounts as well, these pics were taken right before we made brackets. I also just made a new stand to roll around shop that supports from front brackets and just in front of bell housing so we can reattach tranny today. We were just waiting on the clutch release bearing to come in today. Also good to know about the vin info on the V6 vs V8, I know for a fact firewall has different vin as it is a 52 cab on a 48 chassis, for some reason or another they swapped them out my best guess it 52 cab was slightly bigger?
Old 01-29-2016, 01:33 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
Looks like your doing a fine job , have fun with it
Old 01-29-2016, 01:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
..., I know for a fact firewall has different vin as it is a 52 cab on a 48 chassis, for some reason or another they swapped them out my best guess it 52 cab was slightly bigger?
'51-'52 cabs are the same size, different dash and bigger back window.
Old 01-29-2016, 01:55 PM
Tilleyman's Avatar
Tilleyman
Tilleyman is offline
Tilleyman is gaining momentum as a positive member of FTE.
Reminds me of mine when I started...
When I was removing the paint brush applied green paint I found some door art hiding under there...
It said "Harold Coble, Milesburg, PA", which is about 2 hours from my home.
Old 01-29-2016, 03:50 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
Heaven, Im in Heaven ............... You know the song. Anyway great thread, and even better Truck, you had me at the first pic, and it only got better from pic to pic. That is becoming one sweet truck. Congratulations, and thank you for sharing your beautiful work with us. It truly made my day brighter.
Old 01-30-2016, 07:40 PM
killjoybjg's Avatar
killjoybjg
That is awesome I love old stuff like that, all the more reason I wanna keep my door logo
Quick Reply: 48 F1 Jeepers Creepers
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
