engine year?
Old Mar 8, 2012 | 01:52 AM
kornfanjoe's Avatar
kornfanjoe
engine year?
Hello everyone, how can I find out for sure what year my engine was made in so I know what designs were implemented. I have an 05 excursion but i read that they carried over many 04 engines into 05 excursions. Also I read that the torque rating on 05 was upped to 570. I looked on my engine and it says 2005 but its rated at 560 torque?
Old Mar 8, 2012 | 05:59 AM
bismic's Avatar
bismic
Motor Build date: drivers side valve cover.
Truck Buid Date: driver door for the manufacture sticker and top left corner will tell you the build date
(dd.mm.yr convention)
Old Mar 8, 2012 | 06:53 AM
npccpartsman's Avatar
npccpartsman
I know what the production date split in the 03/04 trucks is but I don't know what the production date split is in the 04/05 Excursions. If you can see the HPOP cover on the back of the motor valley you can tell the difference.....
That information might also be posted in the Excursion forum.
Old Mar 8, 2012 | 04:14 PM
kornfanjoe's Avatar
kornfanjoe
Thanks guys! Knowing the engine year can make a huge difference because of all the changes.
Old Mar 8, 2012 | 04:35 PM
bpounds's Avatar
bpounds
You should find your engine build date and serial number on a label on the FICM. Assuming you still have the original FICM shell.
Once you have that serial number, the chart in this thread will be useful.
https://www.ford-trucks.com/forums/8...-identity.html
I think that serial number chart should be in the tech folder, but it hasn't made it there yet. Mods???
Old Mar 9, 2012 | 12:05 AM
Snuggyworm's Avatar
Snuggyworm
or u can go on ford's website and trace ur vin number and u'll be able to get a more technical readout of ur vehicle.
Old Mar 9, 2012 | 12:57 AM
Unrealo4's Avatar
Unrealo4
I'm sure that all 05 excursions had the late production 04 motor. Also they all have leaf springs in the front as well. Ford didn't bother with the upgrades due to it being the last production year.
Old Mar 9, 2012 | 03:27 AM
kornfanjoe's Avatar
kornfanjoe
I know I'm very disappointed I wish I had coils instead of springs they are so much stronger better articulation and still softer. Ford ( and Chevy/dodge) for that matter all focus very heavily on the trucks and everything else gets the back burner. Hence Ford endong the ex.
Gmcbuffalo
Apr 10, 2015 08:22 AM
jdw1
Jul 30, 2009 03:57 PM
Pittsburgh-05HD
Feb 24, 2006 10:10 AM
My4x4Toy
Nov 18, 2004 06:45 PM
