Confussion about build dates???
Old Feb 16, 2006 | 03:03 PM
Pittsburgh-05HD's Avatar
Pittsburgh-05HD
I have an '05 truck...well I think I do. Ford sold it to me as an '05, and the window sticker says '05.
The door sticker (truck build date?) says 9-2004. I cant find the engine build date. I looked on the driver side valve cover and all there is a white sticker with a bar code and my vin number and some other numbers that can't resemble a date. (0226 /8192 /1).
I have to belive that the engine is a 2004 engine. So how can ford sell me a 2005 truck, with all 2004 components? Am I not correct in saying they made inprovements to the 2005's? Would my truck have these?
Any help would be appriciated.
Old Feb 16, 2006 | 03:19 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
If its an '05 Model - it has the improvements, even if it was made in 04
Old Feb 16, 2006 | 11:01 PM
Btravelen's Avatar
Btravelen
On the passenger valve cover toward the back is a yellow sticker. It should say 325hp and 570 ft/lbs torque. Those are '05 specs.
Old Feb 17, 2006 | 02:25 AM
dunn6253's Avatar
dunn6253
From September on(9th month) it is considered the next year for the build date.
Old Feb 23, 2006 | 03:27 PM
Cowboy Tom's Avatar
Cowboy Tom
Now I am confused.....
I have a yellow sticker on the drivers side of the engine: 29-Jul-03 and a red/white sticker on the passengers side of the engine: 2003 model. The date on the drivers door sticker states: 8/03.
The window sticker when I bought the truck and the registration say it is a 2004.
If the month cutoff is 9/30, am I driving a 2003 model but was sold as a 2004 model?
Old Feb 23, 2006 | 03:35 PM
Kep4's Avatar
Kep4
Jäger
Input your VIN on the linked page:
https://www.fleet.ford.com/maintenan...ls/default.asp
Old Feb 24, 2006 | 07:16 AM
Casey's Avatar
Casey
That's wrong. It's considered the next year when the manufacturer changes the designation to the next year. In this case the change from 2004 to 2005 was in July, 2004. All trucks built in July 2004 and later were 2005 trucks with all the 2005 parts.
Old Feb 24, 2006 | 08:12 AM
Kep4's Avatar
Kep4
Jäger
Sorry the link didn't work, this one will:
http://www.fleet.ford.com/
Go to Maintenance and VIN decoder and then type in your trucks VIN and you'll know the build date.
Old Feb 24, 2006 | 08:24 AM
WilliesSD250's Avatar
WilliesSD250
Speaking of the build dates, When I went to change out my sport mirrors for towing mirrors, I noticed dated bar code stickers on the mounting plate for the mirrors...the right mirror had a date that was a friday, the left mirror had a date that was a monday. I kinda had to laugh at that one. Being able to tell exactly when the truck was put together.
Old Feb 24, 2006 | 09:29 AM
kw5413's Avatar
kw5413
'03 engine builds were placed in '04 MY truck builds until approx. '09/28/03. After that date the '04 MY had the '04 engine design with all the upgrades designated for '04.
Old Feb 24, 2006 | 09:47 AM
sandblaster's Avatar
sandblaster
Question
I am also confused. The truck build date on the drivers door sticker and the vehicle invoice show a build date of 1/04, the engine build date code on the FICM is "040204", it does not matter how you read the code it shows the engine build date after the truck build date. I was concerned and had an OASIS run and showed no engine change. Just thought it was interesting.
Old Feb 24, 2006 | 09:53 AM
kw5413's Avatar
kw5413
I only have heard of this if the FICM has been replaced.
Old Feb 24, 2006 | 10:10 AM
EnviroCon's Avatar
EnviroCon
[QUOTE=sandblaster]. . .the engine build date code on the FICM is "040204". . .[QUOTE]
Did they change the format for the build date on the FICM? It used to be DD MMM YY, i.e. 22 OCT 03.
