6.0 PSD Engine Commonization Identity
Old Aug 6, 2009 | 09:32 AM
HeavyTow's Avatar
HeavyTow
I have read two of the 6.0 PSD commonizaion threads and have learned a lot about the changes for this engine. The information states that engines made after Jan. 11, 2006 are considered to be of the commonization version. My questions are: If I buy a truck that has a build date of February 2006 will it have the latest engine? If not what build date for the truck should I settle for to get one of the most trouble free engines? Is there an engine serial number break point that I can look for and what is it? Can you find this serial number by just knowing the VIN?
Thanks,
Heavy Tow
Old Aug 6, 2009 | 01:14 PM
bpounds's Avatar
bpounds
It would be nice if someone had that information. But until then, you can check the engine build date by looking at the sticker on the FICM module on the engine. That is probably a better engine reference than the truck assembly date.
Old Aug 6, 2009 | 01:42 PM
Frankenbiker's Avatar
Frankenbiker
In the "For What It's Worth" department, My 2007 truck's build date was late November, 2006; the engine build date was in July, 2006.
A truck built in Feb of 2006 would probably have a pre-commonization engine.
-blaine
Old Aug 6, 2009 | 02:52 PM
brian42's Avatar
brian42
Veteran: Navy
Truck and engine build dates seldom are the same. The date the engine was built will be on the engine itself. That is the date I would use to determine if it is a commonization engine or not.
Old Aug 7, 2009 | 05:46 AM
Maxium4x4's Avatar
Maxium4x4
Here is another chart, if you like charts
Old Aug 7, 2009 | 09:22 AM
bpounds's Avatar
bpounds
Excellent. Reps coming your way.
Old Aug 7, 2009 | 09:56 AM
HeavyTow's Avatar
HeavyTow
Ask and you shall receive! Maxium the chart was just the ticket. It will give myself and anyone else the info needed to know where they stand on the commonized engine issue. I am currently on the hunt for an F350 and want to be sure I get the better of engines when I buy. As stated in early posts by other members just knowing the truck build date doesn't tell the whole story. Thanks again for the help.
Old Aug 7, 2009 | 10:26 AM
Snapper3's Avatar
Snapper3
Please help my ignorance. Where should I look for the engine serial number on the engine? Also, where is the FICM located? I am disabled and climbing around and over the engine is hard on me. Thanks.
Old Aug 7, 2009 | 10:33 AM
bpounds's Avatar
bpounds
The serial number and date of engine build will be found on a label on the FICM module. The FICM module is above the drivers side valve cover.
Old Aug 7, 2009 | 10:35 AM
Snapper3's Avatar
Snapper3
Thanks for the help.
Old Aug 7, 2009 | 10:39 AM
bpounds's Avatar
bpounds
See:
http://dan.prxy.org/Truck/6L_bible_h.../Page_008.html
http://dan.prxy.org/Truck/6L_bible_h.../Page_009.html
http://dan.prxy.org/Truck/6L_bible_h.../Page_010.html
Pictures are worth thousands of words.
Old Aug 8, 2009 | 01:42 PM
bpounds's Avatar
bpounds
I added some info on this in a new thread. See:
https://www.ford-trucks.com/forums/8...ml#post7808039
Old Aug 8, 2009 | 05:46 PM
smlford's Avatar
smlford
OK, I'll guess I'll be the one to ask the stupid question...
What is the difference between the pre and post comminization engines? I guess by the comments that the post engines are somehow better.
I have an '06 but bought it in 11/05 so I guess I have the pre engine which has been bullet proof so far.
Old Aug 8, 2009 | 06:31 PM
bismic's Avatar
bismic
<TABLE style="WIDTH: 614pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=818 x:str><COLGROUP><COL style="WIDTH: 614pt; mso-width-source: userset; mso-width-alt: 29915" width=818><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 614pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=17 width=818>The commonized engines didn't start until Jan 06. Here is some info I found on them.</TD></TR><TR style="HEIGHT: 133.5pt; mso-height-source: userset" height=178><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 614pt; HEIGHT: 133.5pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=178 width=818 x:str='Subject: 2006 6.0L Diesel Power Stroke Cylinder Head Commonization Effective Date: Ford Production Assembly Plants - January 11, 2006 Kentucky Truck Plant (Super Duty) & Lorraine Assembly Plant (Econoline) Description Changes are being made to the 6.0L diesel cylinder head, head gasket, crankcase block, rocker arm carrier and injector hold down clamps for the 2006 Super Duty and Econoline Program. The action is taking place to facilitate/communize the International manufacturing process for the upcoming 6.4L program. The 2006 6.0L used in Ford vehicles after January 11, 2006 are being referred to as "Commonization Engines". Part number details are provided on a separate excel spreadsheet. '>Subject: 2006 6.0L Diesel Power Stroke Cylinder Head Commonization
Description
</TD></TR><TR style="HEIGHT: 129.75pt; mso-height-source: userset" height=173><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 614pt; HEIGHT: 129.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=173 width=818 x:str="Figure 1 - New cylinder head 1. Carrier boss bolt holes M10 x 1.5 2. Injector clamp bolt holes (relocated) The new cylinder heads have several casting changes including a slight injector clamp bolt hole relocation (2, figure 1) and the carrier boss bolt hole size and location changes (1, figure 1). New cylinder heads also use 32 mm cup plugs replacing the old 28 mm cup plugs. The cylinder head gasket is also new to accommodate the new 20mm cylinder head location dowels. Pre commonization head use 18mm dowels Note: At this time the new cylinder head assembly is not interchangeable with the previously level head. ">Figure 1 - New cylinder head
head.
</TD></TR><TR style="HEIGHT: 51pt" height=68><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 614pt; HEIGHT: 51pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=68 width=818>Figure 2 – Previous Level Cylinder Head
1. Carrier boss bolt holes M8 x 1.5
2. Injector clamp bolt holes (original locations)
Note: The previous level cylinder head assembly is not interchangeable with the new head.
</TD></TR><TR style="HEIGHT: 63.75pt" height=85><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 614pt; HEIGHT: 63.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=85 width=818 x:str="Figure 3 - New Block Assembly The new crankcase (block) uses two 20mm cylinder head locating dowels per head. The old crankcase (block) uses two 18mm cylinder head locating dowels per head. Note: The new and old block assembly is not interchangeable. This affects replacement of all 6009 short blocks and the 6010 bare blocks. ">Figure 3 - New Block Assembly
</TD></TR><TR style="HEIGHT: 102pt" height=136><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 614pt; HEIGHT: 102pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=136 width=818 x:str="Rocker Arm Carrier: Figure 4 - New Rocker Arm Carrier Casting changes to the rocker carrier provide increased clearance for new injector hold down clamps (figure 6). The new carrier also uses only 2 bolts and locating dowels to attach the carrier to the head. The new rocker carrier is serviced in a Rocker Arm Carrier Kit which includes the rocker carrier cover, gasket and necessary dowels. Note: The new and old rocker arm carrier kits are not interchangeable. ">Rocker Arm Carrier:
to the head.
</TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: #ccffcc; WIDTH: 614pt; HEIGHT: 25.5pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=34 width=818>Figure 5 – Previous Level Rocker Arm Carrier Kit
The old rocker arm carrier uses 4 attaching bolts to hold the carrier to the old cylinder head (figure 2).
</TD></TR></TBODY></TABLE>
Old Aug 9, 2009 | 07:30 AM
smlford's Avatar
smlford
Thanks Mark.
It looks like the comminization engines have slightly larger bolts in certain areas and an improved rocker assembly so they should be "better"
dumone59
May 10, 2019 03:52 PM
krifenbu
May 27, 2017 08:31 AM
RickBraden
Dec 8, 2010 06:17 PM
bpounds
Aug 9, 2009 12:50 PM
drewdog
Jul 24, 2009 10:10 AM
