atf question
Old Mar 7, 2012 | 02:37 PM
wizzy214's Avatar
wizzy214
atf question
99 e-250
which tranny fliud?
atf
dex 3 or type f
Old Mar 7, 2012 | 02:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If those are the only choices I'll take none of the above.
Your transmission should use MERCON V. You won't hurt it with MERCON, and MERCON is almost identical to DEXRON III.
Old Mar 7, 2012 | 04:08 PM
wizzy214's Avatar
wizzy214
Old Mar 8, 2012 | 04:29 PM
Mark Kovalsky
If you use this method: Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles you will need 20 quarts.
Old Mar 8, 2012 | 09:35 PM
wizzy214's Avatar
wizzy214
so browsing for deals am i ONLY looking for mercon v?
or is dex/merc ok?
http://www.walmart.com/ip/Valvoline-...allon/15125768
just want to be 100% so i get it right the first time
thanks mark.
Old Mar 9, 2012 | 09:33 AM
Mark Kovalsky
MERCON V is better, DEX/MERC will work.
68camper
Jun 17, 2011 07:30 PM
Roger T. Pipe
Aug 8, 2010 12:17 PM
qdude79
1997 - 2003 F150
May 10, 2006 08:02 AM
preppypyro
1997 - 2003 F150
Sep 28, 2005 09:58 PM
polar88
May 1, 2005 03:41 PM
