Tranny fluid
Old Apr 30, 2005 | 10:08 PM
polar88's Avatar
polar88
Tranny fluid
My truck calls for Mercon ATF. I couldn't find anything with just Mercon on it. It was either Dextron III/Mercon or Mercon V.
Is the dextron III/Mercon what I need or do I need to keep looking?
Old May 1, 2005 | 12:05 PM
jim henderson's Avatar
jim henderson
The DexronIII/Mercon will work fine. To get real Mercon, you need to check Ford Dealers. The Mercon V is not necessarily backward compatible to trannies using Mercon. Mercon is not upwardly compatible with Mercon V only trannies.
You can substitute one for the other but Mercon Mercon V do not meet respective spec for the trannies the work in.
Just use the Dexron III/Mercon. And cahnge regularly, some recommend as often as 12K. I do at 30K since I am lazy. Don't listen to the 100K advice some will give you.
Good Luck,
Jim Henderson
Old May 1, 2005 | 03:41 PM
polar88's Avatar
polar88
Ok, thanks. I was a little sheepish about asking what seemed to be a blatantly obvious question, but I'd rather look foolish in FTE than on the side of the road with a smoldering tranny. Thanks
Stokes
Oil & Lubrication
May 16, 2013 05:49 AM
reed1951
Jan 25, 2013 07:17 AM
sx10
Jan 27, 2010 01:18 PM
Lead_Foot
Aug 3, 2005 07:27 PM
jeff44ranger
Oil & Lubrication
Feb 5, 2003 01:49 PM
