Minnesota Chapter Join Chapter, Leader: fordpower88
Spring is almost here March BS thread!
Old Mar 23, 2012 | 08:21 PM
  #2536
Ford79's Avatar
Ford79
Originally Posted by dlibson
Hey does anyone have a utility trailer with sides I could borrow this weekend?
If you haven't found anything yet, I can get you one.
Originally Posted by Goldy3
SO I am looking for some opinions.When it comes to an air tank would you get a steel or an aluminum. I know the aluminum won't rust but what else is the difference between them?
Personally, I'd just get a steel tank. I know they can rust, but aluminum will corrode as well.
You must be busy at work , any plans for the weekend?
Busy all around. I was thinking of working on removing the box off my truck. That is all so far.
Looks good Dale.
Different bumper or just paint the old one?
Evening all. Another Friday working at home for me... lame
Well Tom, I got some work planned tomorrow moving stuff around, then Sunday working in the yard to get some stuff done.
Hi Dave.
Work, work, work...........
Old Mar 23, 2012 | 08:23 PM
  #2537
Ford79's Avatar
Ford79
Front flower garden cleaned out, bet mat and plastic liner out of truck bed.
Bed bolts-1, T50-0. This isn't going to work too well...........
  #2538
Excursion4X4's Avatar
Excursion4X4
Originally Posted by Excursion4X4
New bumper Jim.
Must of missed it Mike!
Old Mar 23, 2012 | 08:24 PM
  #2539
MisterCMK's Avatar
MisterCMK
Dale stop by when you get back from your trip, I will charge the laptop between now and then.Then I can scan your truck for you
I can also help FWIW
Old Mar 23, 2012 | 08:25 PM
  #2540
Ford79's Avatar
Ford79
YUP. typing at the same time.
  #2541
MisterCMK's Avatar
MisterCMK
Yikes. Cut 'em out!
Old Mar 23, 2012 | 08:26 PM
  #2542
Excursion4X4
Sounds easy to me. Turn the truck on and back up towards a trash can or something like that. <----Chris's Quote.
Need scanner to test each one... Either all the sensors are bad or the module is bad. Not sure which is more expensive. One sensor bad for sure though....ripped it in half removing it from the bracket!
Old Mar 23, 2012 | 08:27 PM
  #2543
Excursion4X4
I could be available tonight if either Chris or Tom is.
  #2544
dlibson's Avatar
dlibson
The bolts are a one time use bolt. They almost always have to be cut off. Then replaced along with the nutserts. Be sitting when you order them too...
  #2545
Excursion4X4
I'd just like to know what I need to replace!
Old Mar 23, 2012 | 08:28 PM
  #2546
dlibson's Avatar
dlibson
Bumper looks way better though Dale!
  #2547
MisterCMK's Avatar
MisterCMK
I will be at the shop tomorrow Dale.
Old Mar 23, 2012 | 08:30 PM
  #2548
Excursion4X4
Thanks Dave!
Old Mar 23, 2012 | 08:34 PM
  #2549
Ford79's Avatar
Ford79
Originally Posted by MisterCMK
Yikes. Cut 'em out!
That's the plan.
I thought I read that at one time. Seems stupid to me, but I guess it is a way to get more $$$ from people that need to remove them.
Should I bring the can of Vaseline?????
Old Mar 23, 2012 | 08:35 PM
  #2550
msmenne17's Avatar
msmenne17
Nice Dale!
