Quick question
Old Feb 27, 2012 | 09:52 PM
rangergirl94's Avatar
rangergirl94
Quick question
How do I add gear oil to my 92 m5r2 4x4?
Old Feb 27, 2012 | 10:10 PM
88n94's Avatar
88n94
You use mercon automatic transmission fluid, not gear oil. There's a fill plug on the drivers side, I believe, a suction gun works best.
Old Feb 27, 2012 | 10:16 PM
rangergirl94
Suction gun? LOL sorry
Old Feb 27, 2012 | 10:36 PM
88n94's Avatar
88n94
It looks like a grease gun with a tube sticking out of the far end. It has a handle on the close end of the tube just like a grease gun. No pump handle on it like a grease gun though. They would know what you wanted at a parts store. Maybe someone else will suggest a better method of filling your transmission.
Old Feb 27, 2012 | 10:40 PM
88n94's Avatar
88n94
Actually you may be able to get a little tip style thing that screws on to a quart container and squeeze the fluid in.
Old Feb 27, 2012 | 10:46 PM
76250_4x4's Avatar
76250_4x4
I use the little nozzle tip that comes on the gear lube quarts. Take it off screw it onto the atf bottle and squeeze it in.
btw: your transmission does not use gear lube. Use regular dex/ merc trans fluid
Old Feb 27, 2012 | 11:12 PM
rangergirl94
Is it the bolt that says drain?
Old Feb 27, 2012 | 11:20 PM
RJJP's Avatar
RJJP
Nope, that's the drain. you need the one that is higher up and says fill.
Old Feb 27, 2012 | 11:47 PM
jborushko's Avatar
jborushko
chiltens haynes manual may be lacking in highly indepth information, but its beginners gold.... best $20 investment you can make
Old Feb 27, 2012 | 11:50 PM
SideWinder4.9l's Avatar
SideWinder4.9l
He can do this, OR...
GO ahead and replace the shifter mount bushings ($15) and fill it from the tower...
2 birds killed with 1 stone..
He got his tranny filled, and the shifter isn't as loose as my ex wife...
Old Feb 28, 2012 | 12:23 AM
rangergirl94
Idk how to replace those bushings
Old Feb 28, 2012 | 01:03 AM
SideWinder4.9l
Pull the shift boot back, there's 3 Torx head screws...GENTLY remove those....The shifter will then pull straight up and out...
On the side of the shifter, you'll notice a "Stud"....has 1-2 nuts (Yeah yeah...hardy har har....Funny)...
It's actually a tapered dowel pin...One side tighten the pin, the other looesens it..
Once you get that off, the actual shifter portion is gonna have an upperr bushing....
And the lower one goes in the tower/hole..
Once you pull everything, it's self explanitory...
And btw...Make sure its in neutral before removing the shifter...
Old Feb 28, 2012 | 02:07 AM
rangergirl94
OK thanks,my tranny whines going down the road is it low on fluid possibly? Its only got 94,000 miles
Old Feb 28, 2012 | 04:25 PM
redmondjp's Avatar
redmondjp
I do exactly as you state, but go one step further: I add about a 1 foot long piece of 5/16" or 3/8" ID clear plastic tubing (available at most home centers) to the nozzle tip, so I can hold the bottle remotely and pour/squeeze the fluid in. Lots of times there is not sufficient room underneath in order to put the bottle in the right position to directly fill the transmission.
Old Feb 28, 2012 | 06:55 PM
UNTAMND's Avatar
UNTAMND
I like tacos.
Yup. Typical that trans is noisy when low on fluid.
Gear lube nozzle and some hose works great.
While you're under there don't just add fluid. Drain what's there, then put all new in.
It's cheap and easy to do.
KILLER'S_60&66
13
Feb 26, 2008 07:04 PM
TxFordGuy
13
Feb 15, 2008 02:52 PM
dionysius
May 6, 2007 03:45 PM
bigdaddyII
Garage & Workshop
May 8, 2005 12:17 PM
TheWiz427
Jun 3, 2004 11:07 AM
