It looks like a grease gun with a tube sticking out of the far end. It has a handle on the close end of the tube just like a grease gun. No pump handle on it like a grease gun though. They would know what you wanted at a parts store. Maybe someone else will suggest a better method of filling your transmission.
I use the little nozzle tip that comes on the gear lube quarts. Take it off screw it onto the atf bottle and squeeze it in.
btw: your transmission does not use gear lube. Use regular dex/ merc trans fluid
I do exactly as you state, but go one step further: I add about a 1 foot long piece of 5/16" or 3/8" ID clear plastic tubing (available at most home centers) to the nozzle tip, so I can hold the bottle remotely and pour/squeeze the fluid in. Lots of times there is not sufficient room underneath in order to put the bottle in the right position to directly fill the transmission.
Yup. Typical that trans is noisy when low on fluid.
Gear lube nozzle and some hose works great.
While you're under there don't just add fluid. Drain what's there, then put all new in.
It's cheap and easy to do.
