Greasing
Old Feb 13, 2008 | 04:14 PM
TxFordGuy's Avatar
TxFordGuy
Greasing
Just bought me an 02 F-250 crewcab 4x4 this past weekend. never had a vehicle before with grease fittings all over the front end. what type of grease do you guys use and how often do you need to grease everything. Thanks
Old Feb 13, 2008 | 04:31 PM
rbaker6336's Avatar
rbaker6336
use a good high impact,water proof grease,several companiea make it,just read the tube
normally bout $3 a tube
Old Feb 13, 2008 | 04:47 PM
greagin's Avatar
greagin
i use lucas red-n-tacky, high heat marine rated etc...
Old Feb 13, 2008 | 05:37 PM
dryfly's Avatar
dryfly
Thats good that you have alot of fittings.I believe they come with non greasable joints.Which would mean they have all been changed by now.And not left for you to foot the bill.
Old Feb 13, 2008 | 05:39 PM
greagin's Avatar
greagin
Not to change the subject, but Bruce that may be the best signature line that i have ever seen!!!
Old Feb 13, 2008 | 06:01 PM
dryfly's Avatar
dryfly
Not my original.I heard or read it somewhere over the years.But its fitting for me.She always says"if you want to know what something costs.Just ask me and then double it"
Old Feb 13, 2008 | 06:03 PM
greagin's Avatar
greagin
surely at some point, all be them potentially different points, it is fitting for us all. Especially when it comes to the prices of guns!! (for me anyway)
Old Feb 15, 2008 | 10:44 AM
TxFordGuy's Avatar
TxFordGuy
how often do you grease yours? every oil change? Thats another question. how often do you change your oil. i'm running synthetic rotella
Old Feb 15, 2008 | 11:03 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I hit a couple squirts at oil change, 5,000 miles.
Old Feb 15, 2008 | 11:05 AM
UP_There's Avatar
UP_There
I do mine every oil change....doesn't take much to over-flow them though! Just do a few sprirts on each one, don't over do it! It will continue to ooze out after it gets warm
Old Feb 15, 2008 | 12:31 PM
highboy390fe's Avatar
highboy390fe
every oil change so 5000 miles, give them all a couple squirts, make sure you dont let them ooze out of it to much can leave a big mess.
Old Feb 15, 2008 | 12:34 PM
dagren99's Avatar
dagren99
Grease
I'm using RONEX MP from Exxon - been very happy w/ it. Meets a bunch of heavy truck (Mack/Volvo/Navistar) requirements for operating life, load shearing req's, etc. The main thing is to choose a grease that meets or exceeds the Ford spec listed in the manual - I always try to hit the exceed side of the mark when I can. This is really important especially if your oil change intervals are out @ the 5-6K or 6month range - you need a grease that can last that long since most people don't lube btw oil changes - some of the thinner greases will be gone after 4-5 months leaving you w/o lubrication and stuff will wear at a quicker rate.
I'm having some difficulties finding it right now. The local Advance Auto/Autozone's used to carry it all the time and now they suddenly seem to have stopped carrying it. They are only carrying some generic junk that I'd never use on anything I cared about.
DG
Old Feb 15, 2008 | 02:39 PM
TxFordGuy's Avatar
TxFordGuy
thanks for the quick responses. what does happen if you over lube them?
Old Feb 15, 2008 | 02:52 PM
maadman's Avatar
maadman
You get a big mess from all the grease dripping out. I myself use a synthethic grease.
