Injector Driver Module
Old Feb 20, 2012 | 10:49 PM
Bonanza35's Avatar
Bonanza35
Originally Posted by mueckster
I was referring to the factors that contribute to combustion. Air and heat. Compression is what builds the heat and air to accelerate and complete the burn process. The wrong amount of these elements will also cause an imbalance.
Thats why guys use to use propane. Complete the burn and cool the combustion chamber so they said. Some have had good luck but you don't here much about it now days.
Chet
Old Feb 20, 2012 | 11:54 PM
fixnair's Avatar
fixnair
I struggled through this for a number of years. I replaced everything I could and finally took it into a shop where they found a bad engine bay wiring harness. They replaced that and I haven't had a problem since.
Old Feb 21, 2012 | 07:53 PM
joeyd61's Avatar
joeyd61
here is an update.....ran compression on the passenger side this evening...
all cylinders ran 180-190 psi after the, "what the "..The tester is a new one "digital"from o-reilys...got a little upset (to say the least) and didnt do the drivers side (should have) but will test tomorrow and hopefully the tester is bad.....Other than a miss the truck seemed to run good and had power.....Is that possible with one whole bank that bad?? (surely not)
Old Feb 21, 2012 | 08:22 PM
BigAlsPSD's Avatar
BigAlsPSD
Ouch, hope it's the gauge. How many miles have you put on the motor Joey? Did you try dropping some oil in to see if compression came up?
Old Feb 21, 2012 | 08:29 PM
joeyd61's Avatar
joeyd61
It has less than 590....yes put oil in #5 and compression went to 999...off the scale on the guage.....I still can't believe every cylinder is bad on the passenger side.....
Old Feb 21, 2012 | 09:10 PM
caverjoe's Avatar
caverjoe
What are good compression numbers??
Old Feb 21, 2012 | 09:16 PM
BigAlsPSD's Avatar
BigAlsPSD
I'm not sure if there was a spec for "new"(somewhere around 400-450psi probably) but you want more than 350-375psi across the board.
Old Feb 21, 2012 | 09:19 PM
BigAlsPSD's Avatar
BigAlsPSD
I'm not sure what kind of "break-in" is required, probably couple thousand miles, but I also wouldn't think it would be that low either... I'd venture to say the DS is about the same though. Was the motor warmed up? I have rebuilt 2 although I have not had "misses" after all the air was worked out though to even see what compression was after the builds.
Old Feb 22, 2012 | 12:01 AM
Bonanza35's Avatar
Bonanza35
Boy that is low. Get a new gauge with a dial and needle. I bet it reads true then. Even Harbor Frieght has them cheap. I can't wait to see the difference.
Chet
Old Feb 22, 2012 | 09:07 AM
joeyd61's Avatar
joeyd61
no the motor is cold at this point.....
new news-----GAUGE IS BAD!!!! we will have a new one tomorrow...put air to the gauge and @125psi it is only showing 40....now back to my miss
Old Feb 27, 2012 | 06:19 PM
joeyd61's Avatar
joeyd61
well,the saga continues.....in the search for the miss, found cylinder #5 had a hit and miss with compression...Hum,sticking valve??so we pull the head
sure enough,exhaust manifold wet with diesel,back to the builder with the head.....Man, I do love my truck
Old Feb 27, 2012 | 11:03 PM
Bonanza35's Avatar
Bonanza35
Great you found the cyclinder. What was the cause. The picture of the block was unclear. You think valve? I'm guessing thats what you think.
Chet
Old Feb 28, 2012 | 07:32 AM
  #28
joeyd61's Avatar
joeyd61
Chet
yes, I am believing exhaust valve,exhaust port and exhaust manifold on cylinder 5 is wet with diesel...Builder said nothing wrong with the head ..I have taken it to another shop for conformation at this point
Old Feb 28, 2012 | 07:45 AM
  #29
mueckster's Avatar
mueckster
Simply drying things up with some brake cleaner and pouring some fuel into the ports should verify a leaking valve. A good shop should be able to vacuum test the valves. Were the valves lapped to the seats?
Old Feb 28, 2012 | 11:26 AM
  #30
joeyd61's Avatar
joeyd61
Roland,
when it was found,we did a leak down test and it was coming out the exhaust....as far as lapping the valves, i don't know about when it was built but the builder did lap them when i took the head to him yesterday..
I have it at another shop for vacuum test today..
Powerßroke
Sep 27, 2017 09:11 AM
nuke tech
Aug 8, 2013 09:05 PM
pilgrimbizket
38
Aug 4, 2013 08:46 PM
Sharonl12
37
Jul 1, 2013 03:13 PM
fixnair
Feb 20, 2011 08:22 PM
