1978 - 1996 Big Bronco
Limited slip code?
Old Feb 10, 2012 | 01:10 PM
jimbo285's Avatar
jimbo285
Limited slip code?
Does the door data sticker have a code that says if you have a limited slip in rear or front? Am gonna drain and refill with synthetic gear lube and need to know if i need to add some additive for the diff. She dont want to move when it's 50 below zero. Hopefully no more of that this winter though.
Old Feb 10, 2012 | 02:51 PM
NewEnglander's Avatar
NewEnglander
Not 100% if its on the door tag but when you take the cover and look at the diff if theres no clutch plate in the middle of the spider gears then you most likely will have an open diff. I replaced mine with a limited slip from an explorer and I think it was like 4oz of friction modifier that has to be added to
Old Feb 10, 2012 | 03:55 PM
critterf1's Avatar
critterf1
Should be on a "tag" on one of the differential cover bolts.
Old Feb 11, 2012 | 12:05 AM
greystreak92's Avatar
greystreak92
Stock Bronco never had an LS up front and the rear axle tag has an "L" between the numbers.
Old Feb 11, 2012 | 06:45 AM
b4hntn's Avatar
b4hntn
Yes, and when you pull the cover the LS has a big "S" shaped spring in the middle of everything.
Old Feb 11, 2012 | 07:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1959 thru today:
If the AXLE code stamped on Rating/Warranty Plates (1959/80), printed on Certification Labels (1981 to date) begins with a letter: Limited Slip.
If the AXLE code begins with a number: No Limited Slip.
This pertains to the rear axle only.
The axle ID tags for Dana's, Sterling's, 8.8's and etc are located under one of the bolts used to retain the inspection cover to the housing.
Do not be surprised if the tag is missing, because this is a very common occurrence. Peeps forget to re-install the tag after bolting the cover back on.
9" rear axle: The rear axle tag is located under one of the bolts (usually at 5 o'clock) that retains the carrier (pumpkin) to the housing.
Again, do not be surprised if the tag is missing.
Old Feb 11, 2012 | 12:22 PM
GruesomeJeans's Avatar
GruesomeJeans
So i think i have an LS then cause i have a 3 digit code on my door tag and under AXLE it has H:
As far as i am aware there no more diff tags on mine.
Old Feb 11, 2012 | 12:23 PM
jimbo285's Avatar
jimbo285
Thank everybody and im glad to see you back grey.
Old Feb 11, 2012 | 02:17 PM
NumberDummy
Three digit code has nothing to do with Limited Slip, only the H2 does
AXLE code H2J
H2 = Ford 9" Rear Axle / 3.50-1 / LIMITED SLIP // J = Power Steering.
Old Feb 11, 2012 | 06:37 PM
GruesomeJeans
Oh so my bronco has a LS then, cool. Thats a little bit more to know about it, thanks NumberDummy
Old Feb 11, 2012 | 09:04 PM
jimbo285's Avatar
jimbo285
So what does a H9 say? Limited slip is the H, what is the 9 for?
Old Feb 11, 2012 | 09:07 PM
GruesomeJeans
Mine looks like H3 actually... Is that the same as an H2?
THEDON117
Mar 4, 2009 04:17 PM
Rich in CO
1997 - 2003 F150
Nov 13, 2006 07:24 PM
coplin
Aug 21, 2004 04:23 PM
cmoore99
16
Jul 25, 2003 08:44 AM
ExplorerEB96
Dec 14, 2001 12:55 PM
