If you can't read the tag, jack both rear tires off the ground and turn one tire by hand. If the other tire turns the same way, you have LS, if the other tire turns the opposite way, you have the open rear.
Okay I couldn't find crap on the door sticker. So I looked on the tag on the diff. It said L 73 and then a bunch of numbers after that. So is it safe to say I have a LS diff? Does anyone know what the rest of the numbers mean? Is there a website that breaks all that down for you, just curious?
Okay, since I found out I have a LS I need to service both diffs.
Everyone has their opinion on what oils they like to use but I'm looking to see the general concensus on a good full synthetic gear oil that doesn't rob the bank along with the friction additive if it's not already in the oil.
