Sponsored by: Auxito
01 rear diff LS?
Old Nov 12, 2006 | 07:28 AM
Rich in CO's Avatar
Rich in CO
01 rear diff LS?
We need to change the fluids in the front & rear diff on my brothers 01 how can I tell if the rear is a LS or not.
Thanks
Rich
Old Nov 12, 2006 | 07:57 AM
steve(ill)'s Avatar
steve(ill)
when you open eth erear cover to drain, you will see the clutch on one side for LS. there is also a stick or tag on one of the pan bolts. i dont know the code, but that tells you prior to pulling the cover.
Old Nov 12, 2006 | 08:00 PM
hi_voltage's Avatar
hi_voltage
Call the dealer with the VIN and they'll tell you what you've got.
Old Nov 12, 2006 | 08:34 PM
Racerguy's Avatar
Racerguy
Welcome to the forum hi_voltage
Rich, on the tag on the diff there will be a bunch of number. There should be something like 3 55 or 3L55 if it's limted slip.
You can also look at the VIN tag on the door post. There is a box that's called "Axle". The codes are
18 — 3.08, non-limited slip
19 — 3.55, non-limited slip
26 — 3.73, non-limited slip
27 — 3.31, non-limited slip
H9 — 3.55, limited slip
B6 — 3.73, limited slip
Old Nov 12, 2006 | 09:14 PM
Dustin1690's Avatar
Dustin1690
I got a quick question so would that axle code apply to the 87-96 F-series trucks cause my 93 says 19 and i have been trying to figure it out im guessing it does so i have a 3.55 non limited slip so that means one tire spins only?
Old Nov 13, 2006 | 06:39 AM
Rich in CO's Avatar
Rich in CO
Thanks guy's I'll grab the numbers.
Old Nov 13, 2006 | 03:17 PM
LxMan1's Avatar
LxMan1
Yes, Dustin, that would be a 3.55 open (one legger) 8.8 rearend.
Old Nov 13, 2006 | 07:24 PM
Dustin1690's Avatar
Dustin1690
Ok thank you very much appreciate it
coreyallan01
Jan 11, 2014 11:55 PM
rangergirl94
Feb 19, 2012 12:53 AM
mattd860
1983 - 2012 Ranger & B-Series
Mar 20, 2009 06:21 AM
mikeyswood
Offroad & 4x4
19
Mar 19, 2007 10:11 AM
desrcr
Jul 2, 2006 07:53 PM
