Rear differential?
Old Jul 21, 2003 | 11:45 AM
cmoore99's Avatar
cmoore99
Rear differential?
I have a '92 F150, 4.9L, M50D. How do I tell what type of rear differential is in my truck? Limited slip vs. whatever else they put in these trucks. I want to make sure I am running the right kind of rear diff lubricant. Thanks for any insight you can give me.
Old Jul 21, 2003 | 12:17 PM
jbalestri's Avatar
jbalestri
Rear differential?
You can do one of many things.
You can look up the code on the door jamb under "axle code" and post it here or look it up.
You can crawl under the truck, there should be a tag bolted to the diff. The bottom row(I think bottom row) should have something like 3 55 or 3L55. Usually the first number is hidden by the bolt. The L stands for limited slip.
You can jack up the rear end, one side and see if you can turn the tire easily, with the truck in gear. If you can turn it, it is an open diff.
You can take the back cover off the diff and there would be clutch packs and a whole bunch of stuff other than the spider gears, etc.
Personally, the first option would be my choice. You can also call a local dealer and ask for the parts department. They can tell you what the code stands for.
Old Jul 21, 2003 | 12:44 PM
cmoore99's Avatar
cmoore99
Rear differential?
Thanks for the reply. The axle code on my truck is 18. Is this a limited slip diff? If not what type of lubricant should I be using?
Thanks
Old Jul 21, 2003 | 12:52 PM
jbalestri's Avatar
jbalestri
Rear differential?
https://www.ford-trucks.com/forums/s...52B%25252Bcode
A search revealed this. It is 3.05 gears and an open(non-limited slip) rearend.
80W90 gear oil should be fine for it without any additives.
Old Jul 24, 2003 | 12:36 PM
steve83's Avatar
steve83
Rear differential?
18 is an open 3.08.
Old Jul 24, 2003 | 12:39 PM
jbalestri's Avatar
jbalestri
Rear differential?
Thanks steve. I mistyped or misread your reply to the other thread.
Old Jul 24, 2003 | 01:32 PM
gudoldboy's Avatar
gudoldboy
Rear differential?
ok where can I find a code sheet showing what type rear i have. This is my first Ford and you guys have been so helpful its not funny. My axle code is a 17 and the tranny code is a U.
Thanks again for all your help!!!!
Aaron
95 F-150 Ext. Cab 4x4
Old Jul 24, 2003 | 02:06 PM
steve83's Avatar
steve83
Rear differential?
This link has those charts in the information section, but put "f150" in the Model field; not "f-150". Also, this page and this PDF direct from Ford.
Old Jul 24, 2003 | 02:17 PM
gudoldboy's Avatar
gudoldboy
Rear differential?
Steve Thanks for the quick reply!!!!
You are da MAN!!!
One problem though. I cant find the code for a "17" rear axle.
Any ideas???
Aaron
95 F-150 Ext Cab 4X4
Old Jul 24, 2003 | 02:29 PM
steve83's Avatar
steve83
Rear differential?
Old Jul 24, 2003 | 02:31 PM
gudoldboy's Avatar
gudoldboy
Rear differential?
Thanks again Steve!!!
Aaron
Old Jul 24, 2003 | 05:07 PM
84Maztang's Avatar
84Maztang
Rear differential?
My Axle code on my 1987 F-150 is H5?????? I dont see any H5 code on any of these charts??? I have a picture of my tag on my website if you don't bielieve me. THe closest thing is H9? What do you guys think?
www.geocities.com/mazdaforpresident/engage.html
Old Jul 24, 2003 | 05:10 PM
84Maztang's Avatar
84Maztang
Rear differential?
Old Jul 24, 2003 | 09:43 PM
steve83's Avatar
steve83
Rear differential?
Originally posted by steve83
This link has those charts in the information section...
Old Jul 25, 2003 | 07:16 AM
StrangeRanger's Avatar
StrangeRanger
Rear differential?
H is a trac-lok
5 should be a 4.10
