Fluid Leak
Old Feb 3, 2012 | 07:50 PM
gup's Avatar
gup
Fluid Leak
I have a 2011 SCREW Eco-Boost with a build date in April 2011. I have a gravel driveway. When I first got the truck I noticed small dark spots in the gravel but attriubuted it to the A/C. I parked over some fresh snow the other night and found some fluid stain on the ground in the morning. It was kind of by the motor and then a little further back. It was the color of yellow/chartruse antifreeze but the truck has pink antifreeze in the overflow tank. Anybody know what is going on?
Old Feb 4, 2012 | 04:44 AM
shotgunz's Avatar
shotgunz
Maybe? https://www.ford-trucks.com/forums/1...n-sitting.html
Old Feb 4, 2012 | 05:33 AM
NASSTY's Avatar
NASSTY
2011 F150's built between 4/15/11 and 6/6/11 could have leaky front pumps on the transmissions.
Old Feb 4, 2012 | 08:34 AM
gup's Avatar
gup
Thank you for the replies. Is Ford's tranny fluid yellow/chartruse color? That is a new one to me and I can't check because no dip stick. I have only seen red previously so didn't even consider it.
Old Feb 4, 2012 | 08:53 AM
NASSTY's Avatar
NASSTY
I'm not really sure?? I also would expect the tranny fliud to be red. But since your build date falls within the time frame of the leaking pump issue you should at least take a look. If you have one of these covers (pictured below) under the transmission you should drop it down and look around the bellhousing area for signs of the pump leaking.
Old Feb 4, 2012 | 10:21 AM
gup's Avatar
gup
Thanks. It is still under warranty and going in for a oil change so I will have the dealer check it out. But now I have knowledge of what might be going on. Thanks again.
Old Feb 29, 2012 | 11:32 AM
gup's Avatar
gup
Took the truck in last week for an oil change and the dealer could not find any evidence of a leak. We received a lot of snow last night in central MN and there were the same yellow/chartruse spots under the truck again. I took some nice color photos to show the dealer.
Old Feb 29, 2012 | 01:32 PM
JeffHann74's Avatar
JeffHann74
Perhaps you have a critter taking refuge under your truck and uhhhh... when you gotta go you gotta go,
js139
6.7L Power Stroke Diesel
15
Feb 9, 2017 10:19 AM
ninaone
Feb 7, 2011 03:16 PM
Designcriteria
May 17, 2010 04:45 PM
thunderz11
Apr 28, 2008 07:01 PM
HP junkie
Jun 29, 2003 02:09 PM
