installing door speakers
Old Feb 3, 2012 | 12:58 PM
Tees77f150's Avatar
Tees77f150
I followed fmc400's lead on both the wiring, and speaker choice with no problems at all. I did a write up with picture a fews years back on installing the window felts, speakes installation in my door, and drilling the hols etc if you do a search.
Old Feb 3, 2012 | 01:00 PM
crsweet78's Avatar
crsweet78
The doors have drain holes in the bottom so water does get in there, but Im sure mine leaks a little more than normal. I bought new LMC felts 4 years ago and theyre already ruined. All the felts falling off and theyre cracked. So theres no way Im putting a nice set of speakers in without some protection from water and dust. Does anyone know where to buy a quality set of door window seals from. That last longer than 4 years.
Old Feb 3, 2012 | 02:00 PM
fordnurse's Avatar
fordnurse
I planned on getting mine from dennis carpenter.. I heard they have quailty anti-rattle felt..I believe it was $60 a pair...then the vents were extra
Old Feb 3, 2012 | 02:40 PM
badbootbob's Avatar
badbootbob
I took a couple Springs and hooked them under the dash. Tied a knot in some heavy duty wire under the dash & inside the door.Hook the spring through the knot under the dash. Use hard plastic gromets for the wire to slide through. No more pinched wires! A good way to line your holes up is to run a screw into the door frame where you want to run your wires. Close your door so the screw marks the paint on the door then drill the holes to size for your gromets.
tbruz
Aug 16, 2015 06:30 PM
archon
Mar 20, 2012 11:47 PM
union bubba
Apr 6, 2011 02:11 AM
tcbofade
Mar 26, 2007 12:15 AM
n9lhm
Mar 7, 2006 07:22 AM
