installing door speakers
Old Feb 2, 2012 | 06:36 PM
Bigbruce's Avatar
Bigbruce
What do I want to use to protect hide the speaker wire as it passes into the door from the cab ? What was original and do they reproduce it ?
Old Feb 2, 2012 | 06:58 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Dennis Carpenter reproduces the door wiring harnesses.
If you truck wasn't equipped from the factory with door speakers, you'll have to drill some large holes for the harness plugs and grommets to pass through.
Old Feb 2, 2012 | 07:48 PM
fmc400's Avatar
fmc400
MSEE
I just used grommets and plastic flex tubing.
Old Feb 2, 2012 | 08:09 PM
devino246's Avatar
devino246
I took a route similar to fmc and drilled holes for grommets, but instead of flex tubing, I just wrapped the wire in electrical tape and pulled them through. Actually looks almost factory
Old Feb 3, 2012 | 05:50 AM
POPAJON's Avatar
POPAJON
Don't forget to protect the speakers from water and stuff,especially the magnets. Find some empty bleach bottles and cut the top off to fit around the speaker and fit them into the speaker holes in the door. This is not my idea...... but it works great. Popa John
Old Feb 3, 2012 | 06:10 AM
fordnurse's Avatar
fordnurse
Ok papajon talked about using bleach containers for protection....does that affect the sound??? Has anyone thought to use weather resistant speakers in the doors?? I have seen some on crutchfield...didnt know what you guys thought...Should people replace the anti rattle seals before installing new speakers for water control?? I have also thought about doing the grommet thing because mine is just hanging between the door...That's an easy and cheap upgrade...big bruce I never thought about covering the wire from cab to door..all about the details I guess!
Old Feb 3, 2012 | 06:28 AM
POPAJON's Avatar
POPAJON
I believe that some moisture still gets into the door even with new anti rattle felts and as for sound quality..... I don't notice any inside but from the outside it's not as noisy unless you've got the tunes cranked up!! lol I have never seen water proof speakers. I would imagine that they would be on the pricey side, so the bleach bottle trick is cheap and you are kind of recycling to. Popa John
Old Feb 3, 2012 | 09:16 AM
devino246's Avatar
devino246
I'd suggest drilling a 1/2" or larger hole in the bottom of the container to allow some air to move in and out.
Old Feb 3, 2012 | 09:23 AM
fmc400's Avatar
fmc400
MSEE
I've had your standard Pioneer speakers from Best Buy in my doors with no protection for almost 4 years now with no issues.
I did the same thing in my beater LTD when I was a student, and that car had zero weather stripping left - no issues there either. You're fine.
Old Feb 3, 2012 | 10:46 AM
79F150400M's Avatar
79F150400M
Ditto......except that my pass. side wing window does leak a little and twice in 20yrs I've had to replace the speakers.
Old Feb 3, 2012 | 10:58 AM
RunninD's Avatar
RunninD
I ussed a set of speaker baffles, They do two things, first they protect the speaker from dirt & moisture and secondly, they help to direct the sound into the truck, instead of having it echo around in the door. I also used 1 sheet of the Dynamat per door, which helped with the tinny door sound from the speaker and when closing the door.
Here's a link XTC 6-1/2" Speaker Baffles (3-1/4" depth) Protect your speakers at Crutchfield.com
Old Feb 3, 2012 | 11:04 AM
crsweet78's Avatar
crsweet78
Use the foam speaker baffles theyre cheap, easy to install and will protect your speakers. for protecting wires going into the door I use these rubber wire looms. Already has built in grommets. Keep it Clean Wiring DLOOM - AutoLoc Rubber Door Wire Looms - Overview - SummitRacing.com
Old Feb 3, 2012 | 12:20 PM
bdevr's Avatar
bdevr
Door speakers are what's known as "free air" speakers. Meaning that to perform properly they should NOT have any sort of baffle or enclosure. If you have a worse than normal moisture problem in your door, you should figure out why and fix it. Otherwise buy speakers that have poly cones and rubber surrounds. Don't waste your money on paper speakers. If you are really concerned buy marine speakers
Old Feb 3, 2012 | 12:35 PM
crsweet78's Avatar
crsweet78
baffles can hurt sound performance and make speakers sound flat. Cutting a 1 or 2 inch hole out it the bottom side of them helps make them free flowing and still keeps protection from moisture. I replaced all new felt and still get water that gets inside my door. I really dont see how you can completely keep water out of your door especially with the quality of LMC weatherstripping.
Old Feb 3, 2012 | 12:48 PM
bdevr's Avatar
bdevr
You are 100% correct. (btw: the new interior is looking amazing ) I was just throwing in the thought that the speakers should really not be sealed off as water/air tight.
If I'm not mistaken, the doors had weep holes from the factory. I don't think they (or any other doors) were ever meant to be water tight...
