Door speaker wiring
Old Mar 24, 2007 | 10:03 AM
tcbofade's Avatar
tcbofade
Door speaker wiring
OK, it's taken me almost a year, but now I'm getting down to the stupid stuff.
1979 F150 4x4 351M C6. When I bought the truck, it had one working speaker in the passenger side door...drivers side didn't work, and had two big speakers behind the seat that weren't hooked up.
I installed an amp sometime ago, replaced the driverside door speaker, and hooked up both big speakers behind the seat.
Now I want to get picky. Some one (previous owner?) Did a half hearted job on the wiring for the door speakers. Yes, it involves duct tape. I can't tell by looking how Ford had originally wired the speakers in the door. Through them tiny little holes in the pillar?
If anybody has good door speaker wiring, I'd really appreciate a pic or a good description thereof.
Thanks!
Old Mar 24, 2007 | 10:43 AM
prrcatenary's Avatar
prrcatenary
As far as I know, only the factory stereo-equipped trucks came with a speaker in each door. My 78 Bronco had them; there was a harness, the leads to the speakers were labeled "left channel" & "right channel". Yes they were run through the pillar, above the top door hinge if I recall. If you look at a door shell & pillar from a truck without stereo, there is a dimple in each indicating where the holes would go. The harness had rubber boots and a sheath over the portion of wires passing from pillar to door.
Old Mar 24, 2007 | 03:50 PM
Mil1ion's Avatar
Mil1ion
I have to redo mine as time & climate have cracked the insulation on my automotive wiring.
I grabbed some OEM wiring out of a Lincoln for the job.,
This special wire appears to be weather resistant and flexible which is what;s needed for the truck application.
You can see how I drilled a hole and inserted a grommet in my doors to allow the wire to slide a bit and not bend when the doors closed in my gallery.
Old Mar 25, 2007 | 02:51 PM
tcbofade's Avatar
tcbofade
Dennis, I cruised your gallery for an hour last night...if you say they are there, I believe ya...but I couldn't find 'em.
While I'm sure it's not original, I'm much happier now!!
I posted pics in the Missouri Chapter...
https://www.ford-trucks.com/forums/5...olume-2-a.html
Old Mar 25, 2007 | 02:55 PM
Mil1ion's Avatar
Mil1ion
You mean you don't see the image with the wiring running out to the door in my reply above ?
Old Mar 25, 2007 | 02:59 PM
tcbofade's Avatar
tcbofade
I can see the photo in your reply...I checked your gallery for pics of it as well...I couldn't find em. No biggie tho...I got it done.
Old Mar 25, 2007 | 03:00 PM
Mil1ion's Avatar
Mil1ion
I was just saving you from looking by posting it
Old Mar 25, 2007 | 03:02 PM
tcbofade's Avatar
tcbofade
Ahhh. Oops. Must be that "Canadian English"???
Old Mar 26, 2007 | 12:15 AM
Langford Ford's Avatar
Langford Ford
Dennis Carpenter make a OEM harness for the 73-79 Fseries and Bronco for $20.00 in his cataloge
