Best leaf springs for hauling? - Ford Truck Enthusiasts Forums
Old 02-01-2012, 05:07 PM
17witha664x4 17witha664x4 is offline
17witha664x4 is starting off with a positive reputation.
gotta put new leafs on my 75 and i was wondering what to get that would make me able to haul as much stuff as possible with the least amount of sag (coal, wood, scrap iron, farm stuff ect) comfort isnt necessary
Old 02-01-2012, 05:54 PM
thekingofcows's Avatar
thekingofcows thekingofcows is offline
thekingofcows is gaining momentum as a positive member of FTE.
18 wheeler springs...
Old 02-01-2012, 06:40 PM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is offline
Sleepy445FE has a good reputation on FTE.Sleepy445FE has a good reputation on FTE.
Quote:
hahaha Or you could take the leaf pack off any Duece and half for maybe a little better ride than the 18 wheeler springs. If those aren't stiff enough you could step up to the 5 tons truck leaf pack.
Old 02-01-2012, 06:56 PM
blackkawi400's Avatar
blackkawi400 blackkawi400 is offline
blackkawi400 is gaining momentum as a positive member of FTE.
I run air bags over the leafs and air them up when I haul heavy loads. When you're doing normal driving though, you can let them out and have a stock riding truck.
Old 02-01-2012, 07:00 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE F-250 WARHORSE is offline
F-250 WARHORSE has a good reputation on FTE.F-250 WARHORSE has a good reputation on FTE.
Hendrickson Long Leaf We used that on heavy haul trucks. !!
Seriously, like a normal stock springs in good shape seem to be fine. If you are getting sag, probably need re arched or replaced. I had a 1994 dodge 2500 CTD that I used as a farm truck with a 105 gallon drag up tank for diesel and usually had tools, oil, shovel, and general stuff us farmers can't live without, and when I baught it it handled the weight fine. When I sold it the fuel tank alone would squat the thing 2-3" so the springs went from good to wore out under my administration.
Freshen up the stockers and maybe add a leaf and I bet it will haul plenty.
Old 02-03-2012, 04:11 PM
hillbillyk hillbillyk is offline
hillbillyk is starting off with a positive reputation.
I put a set of springs from an 84 f-350 cab and chassis dump truck on my 75 f-250 4x4, took them to the local spring shop for new bushings and add a leaf to them, they are an 11 leaf pack now. I was planning on running a mason dump bed but kept the reg. bed on it. rides rough but no sag at all with my trailer or loaded up with scrap.
Old 02-03-2012, 04:22 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
OEM to specialty hauling.... Contact Eaton Detroit Springs... Eaton Detroit Spring Home
Switching my 3/4 ton leaf springs to 1 ton, is it possible? '99F250 1999 to 2016 Super Duty 13 12-23-2015 05:00 PM
Lowering F350? Mike944 1987 - 1996 F150 & Larger F-Series Trucks 2 12-15-2015 05:35 PM
2008 f250 rear leaf spring bushings Mach1394 1999 to 2016 Super Duty 4 08-24-2015 09:51 AM
F-100-600 Rear Leaf Springs Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 03-18-2015 10:45 AM
Leaf Spring Rebuild 70T351W 1994.5 - 1997 7.3L Power Stroke Diesel 11 07-07-2014 08:59 PM
Tags
18, hauling, leaf, springs, truck, wheelers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
