Starter Problems
Old Jan 20, 2012 | 11:32 AM
Monana ford Man's Avatar
Monana ford Man
Starter Problems
I have a '77 F-250 2wd CS with the 400. When I start the truck in the morning, the starter turns the motor fine, however when the truck warms up, and is restarted, the starter barely turns the motor over. Is this problem normal, as I have talked to several owners with the same issue?
Old Jan 20, 2012 | 01:35 PM
montana_highboy's Avatar
montana_highboy
Could be a number of things, starter's giving up the ghost, heat soak, timing too far advanced, corroded cables, bad connections, etc.
Old Jan 20, 2012 | 03:53 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Does your truck have headers?
If it does, it could be heat soak. You'll need to shield the starter from the heat.
If not, it could be timing, the starter giving up the ghost, battery about to do the same or a bad ground. Make sure the battery cables are clean, tight and in good condition. Make sure the ground cable to the block.
websthes
Oct 4, 2006 11:20 AM
BuckTruck
22
Jan 28, 2005 03:07 PM
themaker
Jan 9, 2005 01:12 PM
gordo350
Nov 19, 2004 06:22 PM
ladewigm
Nov 6, 2003 06:50 AM
