smokin starter
Old Nov 16, 2004 | 05:27 AM
gordo350's Avatar
gordo350
Unhappy smokin starter
When I tried to start my truck today it would only just turn over slowly then stop, like the compression was too much for a weak battery. (Battery if fully charged).Then I noticed a burning smell.Looked under the bonnet and the cable that runs from the starter solinoid to starter was smokin and was hot enough that it melted the solder in the joint. What will cause this . Have I got a bad battery or solinoid or starter. Its a 240 I6 in a 65 f 350.
Old Nov 16, 2004 | 06:20 AM
barry's Avatar
barry
Sounds like either bad connections at your cables ( ground, etc...) or your starter is on the way out. Clean all connections and try again. If the cable get hot like that again, replace the starter.
Barry
Old Nov 17, 2004 | 04:47 AM
jowilker's Avatar
jowilker
Sometime when cables get old and full of corosion they don't work well. A new pair of cables is pretty cheep, and can make a world of difference.
John
Old Nov 18, 2004 | 07:04 PM
spurredon's Avatar
spurredon
Just being loose can cause connections to arc. As previously stated, check them all. You can disconnect the starter side of the solinoid and see if the situation repeats itself and if it does the problem is not on the starter side. The old process of elimination, you get the pic!
Old Nov 19, 2004 | 01:42 AM
gordo350's Avatar
gordo350
Red face
checked all connections and it turns out the nut on the starter side of the solenoid was tight but not actualy clamping the cable end thus creating an arc. When I tried to undo said nut, it broke off. So , new solenoid and $25 bucks later , it lives and breaths again. Thanx guys
Old Nov 19, 2004 | 06:22 PM
spurredon's Avatar
spurredon
I'm always glad when it is something simple! Glad you are back on the road. I might get a chance to get mine out in the morning before the PM rains but snow is in the forcast so it will be up for the winter pretty soon. Spring is a long time away!!
McKenny
Oct 15, 2011 11:19 AM
eddie v
Dec 7, 2010 04:27 PM
bassman4
Jun 2, 2010 07:30 PM
josh nowak
1983 - 2012 Ranger & B-Series
Jan 4, 2007 10:43 PM
vern
Feb 13, 2001 03:06 PM
