351C Starting Problems
Old Nov 4, 2003 | 01:18 AM
ladewigm's Avatar
ladewigm
I have a strange problem..
My truck starts perfectly when it has been standing over night or for a long time and is cold, but as soon as I drive it and it gets hot it struggles to start. I still have the standard coil etc on the engine.
Any ideas?
http://www.f100.1965.8m.com
Old Nov 4, 2003 | 02:48 AM
macguyver's Avatar
macguyver
Could be heat soak affecting the starter or the timing is advanced a little too far.
First check the battery and cable connections, especially the starter cable. Then try moving the timing back a little when it acts up. If you've got headers, make a heat shield to go between the header and the starter.
If those don't help, it's probably time for a new starter.
Just my 2¢
Greg
Old Nov 4, 2003 | 08:34 AM
ladewigm's Avatar
ladewigm
Thanks for the tips. I will check the cabling again and also the timing. I still have the stock exhaust manifold so I am not sure if they caused this problem. The starter motor is a little poked but I plan on rebuilding soon.
Old Nov 4, 2003 | 09:15 PM
ncl's Avatar
ncl
Try routing the starter cable away from heat also If the wire gets too hot it causes it to produce more resistance to current flow thus causing the starter to buck like too far advanced timing.
Old Nov 5, 2003 | 08:54 PM
danlee's Avatar
danlee
I always had that problem until I went to #2 Gauge cable from the battery to the solenoid, and from the solenoid to the starter.
Also I use #2 Gauge cable from the battery (-) terminal to the ground connection.
Auto store cable is #4 gauge.
Old Nov 5, 2003 | 09:29 PM
dbarracuda's Avatar
dbarracuda
So if the stuff in auto stores is 4 gauge where did you get 2 gauge?
David
Old Nov 6, 2003 | 06:50 AM
danlee's Avatar
danlee
You probably have to ask at the counter.
yargnitram
Apr 10, 2016 10:27 AM
johnmel59
Jan 4, 2016 10:37 AM
Brandon Harrison
34
Apr 13, 2014 12:17 AM
Waylon Fan
16
Sep 1, 2012 02:11 PM
Jonesy0027
Aug 21, 2012 11:17 PM
