Correct/recommended ground wires in engine bay?
Old Jan 5, 2012 | 08:52 PM
Myfreeford's Avatar
Myfreeford
I have one main ground wires in my engine bay - that goes from the block to the negative terminal on the battery - there are smaller ones that ground the lights, ww pump, etc, but I am primarily talking about the main ground wires. Should there be a couple more? Block to chassis? Chassis to firewall? Block to firewall?
I recently installed a new wiring harness and believe I have some grounding issues. My main concern right now is the alternator is not charging. Had it tested twice and it tests good. Multimeter shows 12.5V on the battery when engine is off and when running.
Old Jan 5, 2012 | 08:55 PM
HIO Silver's Avatar
HIO Silver
At a minimum, I recommend:
  1. Block to battery neg terminal
  2. Block to cab
  3. Cab to frame
  4. Bed to frame
Old Jan 5, 2012 | 09:02 PM
mark a.'s Avatar
mark a.
You can never have too many grounds. IMO the most important one the factory left out for what ever reason, would be one from the motor to the frame.
Old Jan 5, 2012 | 10:07 PM
jeff14346's Avatar
jeff14346
defently a great question, my 390 has a large bolt going into side of block just behid alternator, I think it is 11/16 or 3/4, battery cables are 1/2 inch, I trying to drill to enlarge I think it will break the cable terminal end.
is there a down sized lug that might bolt into the block and allow a down size to bolt bable end to?
Old Jan 5, 2012 | 10:14 PM
CaptainIPSC's Avatar
CaptainIPSC
if you want your radio to work better.
Hood to firewall!
Old Jan 5, 2012 | 10:35 PM
bamaf150's Avatar
bamaf150
My neg cable off the battery is attached to that bolt. Might be simpler for you to buy a new neg cable with a larger terminal end to fit that bolt. Or cut the smaller terminal off the old cable and solder a larger one on.
Old Jan 5, 2012 | 10:50 PM
jeff14346's Avatar
jeff14346
I will hit up parts store and see what I can find
thanks
Old Jan 6, 2012 | 12:59 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The factory was kind of weak when it came to grounds. Besides the neg. battery cable to block, there was a block to firewall, and an alternator to regulator/rad. support ground. There was also a hood to firewall ground but that was to increase the ground plane for the radio antenna.
Like mark a said, you can never have too many grounds.
Besides the three above, I've added a starter to frame and a rad. support to frame on my project. And when I get the cab and bed back on I'm going to add ground to frame straps on them too.
Old Jan 6, 2012 | 07:53 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I can't count the number of problems I have solved by adding a firewall to engine ground strap.
Old Jan 6, 2012 | 09:57 AM
Myfreeford's Avatar
Myfreeford
Wow - thank you! Pictures and information are very helpful. I will be picking up more cables to ground my truck today.
Old Jan 1, 2024 | 04:26 PM
1TonBasecamp's Avatar
1TonBasecamp
If you’re not doing a concourse restoration, it doesn’t matter that you place the ground straps precisely where Ford did it. Just ground the cab to the body anywhere that is convenient (and won’t cause a rust problem) and go to town.
Old Jan 1, 2024 | 04:29 PM
1TonBasecamp
And I must be thinking of my old 83, and 93 pickups. I just crawled under my 79 and I’ll be darned if I can find one.
Old Jan 1, 2024 | 08:44 PM
aldridgec's Avatar
aldridgec
I think it's a weenie one that's clips from the cab mount bracket to a piece of sheet metal. A dedicated one at the block to the frame would be an improvement.
Old Jan 2, 2024 | 06:33 PM
tbear853's Avatar
tbear853
I'd do
  • each door to cab at front of door
  • hood to cab cowl / firewall
  • each splash panel to the frame
  • cab to floor, likely twice
  • bed to frame.
There are kits with 5-10 ground straps of braided copper, even coated .... that have either 5/16",or 1/4" eyes and are 8 to 12 inches long.
hickory1991
21
Jun 2, 2018 08:04 AM
carlyoung
Apr 5, 2012 07:19 PM
ajm859830
1997 - 2003 F150
Nov 16, 2006 04:40 AM
natron343
Electrical Systems/Wiring
Dec 9, 2004 05:22 PM
jcs1966
Nov 20, 2003 06:53 AM
