Loose gear selector
Old Jan 3, 2012 | 04:28 PM
Furniture Doctor's Avatar
Furniture Doctor
Loose gear selector
Today I tightened two torx bolts on the lower part of the steering column. It required a #30 torx to tighten them up. It seems to be as good as new.
Doc
P.S. I took some pictures but I am having trouble getting them to go the FTE site
Old Jan 3, 2012 | 05:20 PM
liv's Avatar
liv
Pretty common issue with just about all Ford vehicles
Old Jan 4, 2012 | 12:11 AM
Brown Falcon's Avatar
Brown Falcon
I need to tighten mine but couldn't see which bolts they were... pics would be great!
Old Jan 4, 2012 | 01:25 AM
maverick1701's Avatar
maverick1701
^ this.
123456789
Old Jan 4, 2012 | 04:05 AM
kenakena's Avatar
kenakena
Specifically, what steps were required to gain access to the torx bolts ? Tightening them is a job I must undertake soon and any help in that regard will be greatly appreciated.
Old Jan 4, 2012 | 05:05 AM
Lazy K's Avatar
Lazy K
Look right down at the bottom of the steering column, you should see a metal bellcrank with the two countersunk type torx head screws.
Old Jan 4, 2012 | 06:14 AM
427 fordman's Avatar
427 fordman
Old Jan 4, 2012 | 06:25 AM
bruno2's Avatar
bruno2
Nice pic 427!
Old Jan 4, 2012 | 08:14 AM
Furniture Doctor
Loose bolts
You just have to wiggle under the steering column. I used a cheap harbor Freight flashlight to illuminate the area. I tried just using a 30 torx and tightening with my fingers first. then I used a 1/4" drive with the torx to tighten up the bolt. The job took about 10 minutes. It is more awkward than difficult.
Old Jan 4, 2012 | 11:35 AM
Brown Falcon
Thanks for the pic Darin!
Old Jul 16, 2014 | 11:49 AM
Unclesp1's Avatar
Unclesp1
Thanks Buddy Great pic
Hey 427 fordman, the pic was great. I got a 95 F250 w/460. It was acting up cause one of the bolts fell out. I took dash apart and crawled under steering column. Your pic really helped me realize what was happening. Thanks again.
rsullivan21
Aug 29, 2013 03:04 PM
TheWiz427
Dec 6, 2007 08:52 PM
kuduhunter
1978 - 1996 Big Bronco
Mar 24, 2007 11:47 PM
oft
Dec 15, 2001 07:48 AM
