1978 - 1996 Big Bronco
Loose Gear Shift on Column
Old Mar 24, 2007 | 11:34 PM
kuduhunter's Avatar
kuduhunter
I have a 1995 EB Bronco and the gear shift has gotten loose on the column to where you have to really pay attention to what gear you are in. What do I need to do to tighten this up?
Old Mar 24, 2007 | 11:47 PM
westtntrucker's Avatar
westtntrucker
Under the dash, down on the column, there will be two bolts (1/2" i think). Look down there and wiggle the gear selector and you will see where the bolts are. Tighten them up and problem solved.
