3 On the Tree P/S problems
Old Dec 13, 2001 | 06:16 PM
oft's Avatar
oft
My three speed standard power steering column broke. Gearshifter moves all over the place but doesnt move the rods to the trans. I had hoped to find another one but I think my truck is the only one left w/this setup. So I have to fix the one I have. I took the wheel off, removed the blinker assembly but I cant get the collar that the blinker assembly bolted to off. I would bet that that piece is the same on all columns. I've tried just pulling and moved it 1/4 of an inch (yes, I removed the 2 bolts). How does it come off??
Jayson
78 F-100, stuck in third gear.
Old Dec 13, 2001 | 06:55 PM
mk's Avatar
mk
Those two bolts have square heads. One flat side fits into a slot the same size on the column tube. You may have to try pushing and wiggling the bolts until they disengage from the slot so the collar will come off the column.
Old Dec 13, 2001 | 07:57 PM
oft's Avatar
oft
The bolts are completely out. Does the thing wiggle off?
Jayson
Old Dec 15, 2001 | 03:33 AM
deltafordman's Avatar
deltafordman
Old Dec 15, 2001 | 07:48 AM
PetesPonies's Avatar
PetesPonies
I will sell you one if you still want it.
