Loctite ring gear bolts?
Old Dec 5, 2007 | 09:13 AM
TheWiz427's Avatar
TheWiz427
OK now that I've rebuilt the Trac Loc I'm setting everything up today and need opinions. I know the cap bolts need to have loctite but I've read a few things about loctiting the ring gear bolts and have found it to be a 50-50 split on using it or not. Whats you guys opinion?
Old Dec 5, 2007 | 12:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I would use Loctite #271.
Old Dec 5, 2007 | 04:17 PM
TheWiz427's Avatar
TheWiz427
#271? Isn't that the medium strength blue?
Old Dec 5, 2007 | 06:31 PM
rhopper's Avatar
rhopper
I was thinking that 271 was red. The high strength red is what I use when it's not going to come apart for a long time, or ever. Btw, loctite likes to be applied to clean, dry, threads.
Old Dec 5, 2007 | 06:53 PM
doug51f1's Avatar
doug51f1
271 is red and will only come apart if you apply heat, ie torch, heat gun. Melting point is about 350F.
242 is blue and medium strength and is removable. We use it on most everything we build for set screws, or parts that see alot of movement.
222 is medium to low strength and is used on anything with a thread diameter smaller than 1/4".
I use loctite on just about everything that might see vibration (which is most of my truck...haha). I would rather use it than lock (split) washers as they are prone to failure.
Old Dec 5, 2007 | 07:16 PM
fordfaninIL.'s Avatar
fordfaninIL.
Absolutely loctite the ring gear bolts. When you buy a ring and pinion they send red loctite with. You also need to torque the ring gear bolts. I have seen three rears in the last year that the ring gear bolts came lose and ruined the rear end, one of them destroyed the rear end housing. New housing from bone yard - $500-1000, new rear end assembled - $1500, red loctite - priceless.
Old Dec 6, 2007 | 06:14 AM
TheWiz427's Avatar
TheWiz427
None of my stuff has numbers on it but red it is, Thanks guys.
Old Dec 6, 2007 | 06:12 PM
55 f350's Avatar
55 f350
FTE Remembers
there isn't anything i won't loctite i don't wanna have parts falling off .
Old Dec 6, 2007 | 08:52 PM
HT32BSX115's Avatar
HT32BSX115
A ring gear is the one place I would not use locktite.
I would use drillled bolts and aircraft safety wire. You don't want them EVER coming loose. It's sort of like lock tabs on rod bolts.....
Cheers,
Rick
redpepsi31
Mar 29, 2017 01:09 PM
FordTruckfan89
Mar 2, 2017 11:05 AM
Crcase
Apr 4, 2016 01:39 PM
Eallend7
Dec 18, 2012 09:59 PM
ford351powr
Jun 3, 2011 08:42 PM
