door pin install
Old Jan 2, 2012 | 04:32 PM
sunbird79's Avatar
sunbird79
door pin install
I have searched and found several pages about removing door pins. But I’m not finding anything about installing them. I got my truck with the pins already removed. How tight should the new pins be? Should they just tap in? Our will they need a good whack with a hammer? I have tried to install them and they seem very tight. Any ideas here?
Tom
Old Jan 2, 2012 | 04:56 PM
bobj49f2's Avatar
bobj49f2
It's better to have them a little too tight than the least bit loose. You shouldn't have to hit them too hard but they will take a firm hit to get them to go in.
Maybe the door hinge parts aren't from the same door? If post side and the door side are from different trucks the hole might not line up perfectly, causing a slight bind. I'd try to make them work as is before trying to reem them to line them up.
Old Jan 2, 2012 | 06:25 PM
firstrider's Avatar
firstrider
I see you are in Ind . So much for letting the door and hinge side of the cab sit out in the sun and warm up this time of yr. Have a heat lamp or two ? Set up the lamps on a ladder close but not too close to the hinges and the door . Put the pins in the freezer over nite . When ready to install this should help enough to make the pins slide in a little easier .Use some type of lube ( grease on the pins ) Wear a glove to hold the pin as not to transfer body heat to them . Used this method here in Fla. and it helped quite a bit . Good luck .
Old Jan 2, 2012 | 06:42 PM
51PanelMan's Avatar
51PanelMan
You gotta be a scientist to install one of them dang pins.
Old Jan 2, 2012 | 06:50 PM
r_reed's Avatar
r_reed
i thought i read somewhere that replacement (some?) pins come slightly larger to make up for wear in the hinge. i bought a pair of replacements and pounded them one in, never got one completely in.
jefxxo
Jul 28, 2009 09:46 PM
Old Dog 2
Aug 24, 2008 06:42 PM
bct
Jun 9, 2007 11:07 PM
kjg26
Mar 6, 2007 09:31 PM
packing tractor
Sep 18, 2006 11:35 AM
