door pin replacement
Old Sep 16, 2006 | 07:23 AM
packing tractor's Avatar
packing tractor
replacing upper door pins on 93 explorer, any tips before i start.
thank you in advance
packing tractor
Old Sep 16, 2006 | 07:58 AM
F3Beam's Avatar
F3Beam
I did a search and found all kind of tips when I did this 3 weeks ago.
Pretty simple job. Support door, loosen bottom from door side, remove top hinge from door side, use 3/8" bit and drill off ream at bottom of top pin (Upper side on bottom pin), then use some sort of punch to knock pin out. Notice how bushings are placed. Be sure to mark door hinge positions before loosening or removing and realign when reattaching. Gently close door to test shutting.
Old Sep 16, 2006 | 08:08 AM
MisterCMK's Avatar
MisterCMK
Its fairly easy. I used rope to hang the door from the rafters in the garage while it was off my truck. I also used an air cutting wheel to cut the pins in half and then pried them out. Once you dig into it you will be able to see whats going on and how easy it is.
Old Sep 16, 2006 | 01:59 PM
F3Beam's Avatar
F3Beam
That's a good idea! I think I'll try that next time.
Old Sep 16, 2006 | 04:55 PM
boilerperson's Avatar
boilerperson
Wow, what timing
I am working on a 93 Explorer. I spent about 1/2 hour trying to get the door pins out. I gave up because of another commitment but thought I'll see if I can get some info in this forum. From what I have been reading, I think I'll cut the pin in the middle and drive the pins out. This vehicle has the typicle low hanging driver side door. If I like the results I'll do the pins and bushings on my F-150.
Old Sep 16, 2006 | 06:06 PM
MisterCMK's Avatar
MisterCMK
The hardest part (which is actually more time consuming than anything) is aligning the door and getting everything to close nice and tight.
Old Sep 16, 2006 | 06:16 PM
boilerperson
Not removing hindges
I'm hoping I don't have to remove the hindges on the doors and just have to do the pins and bushings. If so I shouldn't have alignment issues.
Old Sep 17, 2006 | 09:00 AM
packing tractor
thank you for your help replacement kit ordered will reply on completion, can't
be any worse than the other projects on this vehicle. thank you again
Old Sep 18, 2006 | 11:35 AM
MisterCMK's Avatar
MisterCMK
I removed the hinge from the door so I could drill out the old bushings and so I could fit the air cutoff tool in there. Its really not that bad to re-align the door, just takes some trial and error. I think me and my buddy got the bushings installed in 15 minutes and the door lined up in 15 minutes.
