1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2003 Expedition Side Mirror Lamp Replacement
Old 01-02-2012, 04:23 PM
wulleebullee's Avatar
wulleebullee
wulleebullee is offline
Talking 2003 Expedition Side Mirror Lamp Replacement
I searched for a while to learn how to get the turn signal/puddle lamp assembly off the side mirrors, but never got the full picture. I finally succeeded, so I took a few pictures for anyone interested. First, move the mirror forward out of the detent. It will expose a screw. Use a T-10 driver to remove it.
Push at top of mirror to expose behind the bottom of mirror. Use screwdriver to push clip to unlock it. The clip is seen better in next picture.
Lamp sockets are removed by ~quarter turn CCW. Don't be surprised to see the lamp assembly is deformed. The hole could be elongated. I had to squeeze it back 'toward round' to get the bulb out. I trimmed the hole a little to easily get the bulb back. Start the assembly at an angle to reinstall, press clip in, and install screw.
It was very easy-- the second time. I got some valuable experience on getting the mirror glass off and getting to the motors.
This should be the same as the F-Series.
Old 01-10-2012, 04:01 PM
rattosh51's Avatar
rattosh51
rattosh51 is offline
Nice write up...
Old 02-19-2012, 08:24 AM
effingpot's Avatar
effingpot
effingpot is offline
Thanks for the photos - I couldn't figure it out until I found your post!
Old 07-25-2012, 06:08 AM
ltramon45's Avatar
ltramon45
ltramon45 is offline
socket
I am having a similar problem. I took it apart except my socket that holds the bulb is broken. Where do i find a new 2 wire socket connector for the little courtesy light. I dont have turn signal mirrors but it looks the same. I am also thinking about switching to signal mirrors just by adding the amber module picture if i can find it.
Old 05-06-2013, 07:19 PM
Jamil Davis's Avatar
Jamil Davis
Jamil Davis is offline
Where did you purchase the replacement bulb?
Old 05-06-2013, 07:44 PM
Hamfisted's Avatar
Hamfisted
Hamfisted is offline
It's a standard 921 bulb (high output) or 916 (standard output). You can get them at Walmart or AutoZone, or any other autoparts store My lens were kinda worn out and had algae in 'em so I picked up a set of the clear Navigator lens online and installed appropriate LEDs in place of the regular bulbs. You can get the LED's from SuperBrightLEDs 194 base LEDs . They are a bit brighter and run much cooler.
-Mike
Old 05-07-2013, 07:34 AM
heymrdj's Avatar
heymrdj
heymrdj is offline
Any ideas on replacement of the amber lens? Does it require a whole assembly? My drivers side lens is cracked so it lets in a bunch of water and molds so it looks just horrible.
Old 05-07-2013, 02:40 PM
Hamfisted's Avatar
Hamfisted
You can buy a replacement factory lens online here:Ford Parts Online for about $50. Or you can find a clear lens on ebay and just put an amber LED/bulb in the turn signal socket, and a clear LED/bulb in the courtesy light socket ( this is what I did...). Or you can buy a complete replacement amber lens from the dealer (probably about the same price...). Or you can buy the complete mirror assembly off ebay or the dealer for a bit more money.
-Mike
Old 03-17-2016, 04:11 PM
lizwharton's Avatar
lizwharton
lizwharton is offline
thank you!
I've been trying to figure out how to get those things off forever!
Old 05-02-2019, 12:19 PM
yockmyer's Avatar
yockmyer
yockmyer is offline
Thank you very much for this post. I was clueless re puddle lamp replacement. Very informative and well done. Thank you again kind sir!
Jim
NotURMailman
1999 to 2016 Super Duty
01-18-2023 06:39 AM
copper1977
2017+ Super Duty
11-23-2021 07:27 PM
sprudo
09-12-2014 02:09 PM
bigdaddyII
2009 - 2014 F150
02-02-2013 08:32 PM
cudamank
11-03-2010 11:57 AM
Quick Reply: 2003 Expedition Side Mirror Lamp Replacement
