How to replace fuel pump??
Old Dec 21, 2011 | 12:12 AM
steventothemax's Avatar
steventothemax
Have the pump by itself ordered. Having a real hard time finding instructions on how to replace just the pump and no the whole hfcm. Any help?
Thanks a bunch.
Old Dec 21, 2011 | 03:36 AM
npccpartsman's Avatar
npccpartsman
It's a fairly simple rebuild and you can refer to this picture for a good breakdown: Page 29: Fuel Supply System
You'll need a fuel line disconnect tool available at any autoparts store (5/16 and 3/8 combo) for about $6. The HFCM has 3 nuts on the outside of the frame that hold it on. You'll have some fuel loss that you can minimize by capping off the tank lines when you remove them.
Old Dec 21, 2011 | 07:44 AM
bismic's Avatar
bismic
I have the WSM pages on it printed out. I will scan them at work and email them to you tonight if you want them.
Old Dec 21, 2011 | 09:17 AM
steventothemax
That would be awesome if its not too much of a problem.
Thanks npccpartsman
Old Dec 21, 2011 | 09:37 AM
dchamberlain's Avatar
dchamberlain
Try these. Bismic's might be more detailed, though.
File Type: pdf
File Type: pdf
Old Dec 21, 2011 | 08:14 PM
bismic's Avatar
bismic
Reps to ya (later) David - those are the ones I had.
Steven - let us know if you need anything else.
Old Dec 23, 2011 | 11:06 AM
steventothemax
gauge installed. 40 psi sitting in driveway (already have blue spring) time to install new fuel pump.
Will be installing ity tonight after work. Thanks a bunch!!!!
Old Dec 23, 2011 | 11:50 AM
cheezit's Avatar
cheezit
check your filters.
audion77
15
Nov 1, 2012 02:00 PM
FatWop69
Jul 11, 2011 12:50 PM
kcmark
Oct 12, 2010 12:24 PM
TurnerBioDiesel
Apr 3, 2010 06:16 PM
fordguy76
Dec 6, 2004 05:34 PM
