Replacing fuel pump
Old Jul 10, 2011 | 08:41 PM
FatWop69's Avatar
FatWop69
Replacing fuel pump
I need to replace the fuel pump in my 2002 excursion. Any input would be appreciated.
Old Jul 11, 2011 | 05:42 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
you need the fuel line removal tool. It's cheap and you can get it at any parts store. Push it in the fuel lines on each side of the pump and pull off the lines. then unbolt pump from frame and remove electrical connection then reverse the process.
It's an easy job if you get the tool.
Old Jul 11, 2011 | 06:45 AM
FatWop69's Avatar
FatWop69
So it's not in the tank
Old Jul 11, 2011 | 10:15 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
If you have a Diesel, no. If you have a gas truck, yes it's in the tank.
Old Jul 11, 2011 | 12:28 PM
FatWop69's Avatar
FatWop69
It is gas, so what about adding a new in line and by passing the one in the tank
Old Jul 11, 2011 | 12:50 PM
FatWop69's Avatar
FatWop69
Is there an access hole or do i need to drop the tank
emayes2000
6.4L Power Stroke Diesel
Dec 25, 2013 08:48 PM
biggyfan1
48
Oct 31, 2013 07:26 PM
Tsisaman
2004 - 2008 F150
Mar 20, 2013 09:49 PM
sillly402
29
May 22, 2009 09:14 AM
brickie
Apr 10, 2009 10:24 AM
