Fuel Pump
Old Apr 3, 2010 | 02:51 PM
TurnerBioDiesel's Avatar
TurnerBioDiesel
Fuel Pump
Hello
Was wondering if anyone replaced the fuel pump in there 6.0 and how is it done. It looks easy but as i found out nothing is easy or cheap with this motor. Thanks
Old Apr 3, 2010 | 03:09 PM
m-chan68's Avatar
m-chan68
Originally Posted by TurnerBioDiesel
Hello
You will need a 13mm socket for the three nuts that secure the pump to the frame rail, and the fuel line release coupler tools to disconnect the line fittings on the engine side. The fuel tank side are a "squeeze and pull" type release. The part number for the pump from Ford is PFB-93. You will also need the update harness 6C3Z-9F759-A if it's a 2003 to 2005 model year.
Old Apr 3, 2010 | 03:19 PM
gearloose1's Avatar
gearloose1
I wonder if it is cheaper to buy the pump from a Marine Diesel dealer... the pump is a standard Parker (Racor) Fuel Conditioning Module.
On mine, it is a P3:
http://www.adpdistributorseast.com/r...Water/7683.pdf
One of the advantages is that the newer ones have a transparent bowl..
Old Apr 3, 2010 | 06:16 PM
TurnerBioDiesel
Thanks. I figured it to be harder. We will see.
mark460
Nov 4, 2019 10:39 PM
genscripter
Apr 5, 2015 10:10 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Aug 6, 2013 06:19 AM
heartnurse73
May 23, 2013 10:55 AM
