Headers?
Old Dec 12, 2011 | 09:25 PM
lightninquick's Avatar
lightninquick
Headers?
I'm looking for headers for my 71. It has a 2 barrel Cleveland.
Old Dec 13, 2011 | 10:46 PM
Freightrain's Avatar
Freightrain
I would think that '73-79 351M would bolt up? I'm thinking the Cleveland head and the "M" motor were the same basic design.
Just a thought.
Old Dec 14, 2011 | 09:16 AM
lightninquick
Thanks for the info.
Old Dec 14, 2011 | 11:38 AM
jowilker's Avatar
jowilker
No Clevelands ever installed in trucks so there are no apps. You will have to do as suggested and make something work. It could bolt up but hit something 6-8 inches away because it was made for a car.
just be aware
John
Old Dec 14, 2011 | 01:13 PM
MIKES 68 F100's Avatar
MIKES 68 F100
wasn't the (m) for midland , but motors were same ? just built in a different plant ?
Old Dec 14, 2011 | 11:15 PM
Freightrain
The Cleveland uses a std small block bellhousing, the M's used a different pattern and aren't interchangeable.
Since 73-up trucks came with M's and the heads are basically the same, the header should bolt to your Cleveland motor. It "should" fit your earlier chassis? No guarantees!!
Old Dec 15, 2011 | 04:02 AM
jowilker's Avatar
jowilker
Believe 77 was the first year for the 351/400M. The FE 360/390 was used through 76.
Getting a M or C to fit the truck isn't much of a challenge, headers for a C in a truck could be. Head bolt patterns for the exhaust can be doable. The struggle can be getting the tubing to get down & out.
You can probable figure it out with with a torch & a big hammer.
John
Old Dec 15, 2011 | 09:14 AM
Rogue_Wulff's Avatar
Rogue_Wulff
just be aware
John
No clevelands were installed in trucks sold in the USA. Aussie trucks did get true clevelands into the 80's.
Not that it makes much difference.
However, as said, 351M/400 headers will bolt to most cleveland heads, though there could be a few oddballs in the cleveland world.
benvaage
Apr 1, 2022 07:12 PM
351Cleveland C4
Dec 28, 2014 09:56 PM
CHAD250CC4X4
Aug 21, 2009 11:18 AM
truckman79
Aug 4, 2003 11:45 PM
fordblue_ca
Mar 6, 2001 11:46 AM
