New Transmission
Old Dec 14, 2011 | 10:01 PM
Creep_E_Er's Avatar
Creep_E_Er
New Transmission
I need a new transmission for my 1970 F-250 Camper Special, or maybe a rebuild kit. I was hoping someone on here might be able to point me in the right direction on my quest to get my truck back up to hauling performance. The current transmission is a 4 speed granny tranny, and it worked just fine before certain people tried to work on it, and would like to replace it with the same transmission or possibly rebuild it.
Old Dec 14, 2011 | 11:18 PM
Freightrain's Avatar
Freightrain
What's wrong with it? Did someone tear into the transmission and screw it up?
Old Dec 15, 2011 | 01:10 AM
Creep_E_Er's Avatar
Creep_E_Er
They replaced the linkage with bailing wire, so now it grinds rather loudly, would you know what specifics I could use to find a replacement, part number and such? I'm in Afghan so can't crawl under it to look lol.
Old Dec 15, 2011 | 01:11 AM
Creep_E_Er's Avatar
Creep_E_Er
1970 F250, 4 speed granny tranny, by the way lol, Camper Special too.
Old Dec 15, 2011 | 02:00 AM
RichS2659's Avatar
RichS2659
Two transmissions are used: Borg-Warner T-18, or New Process 435. To identify which one it is, where is the reverse located from neutral, up or down?
Old Dec 15, 2011 | 07:38 AM
Creep_E_Er's Avatar
Creep_E_Er
Down I believe.
Old Dec 15, 2011 | 08:07 AM
Creep_E_Er's Avatar
Creep_E_Er
Have any of yall had any luck with LMC Truck?
Old Dec 15, 2011 | 09:25 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Down to right would be a NP435. Top cover will be aluminum so magnet will not stick to it. There is no external linkage. If shifter was pulled while in gear, shift yokes are not aligned right. Don't spend money till checked out, these things are tough.
oldbird1965
19
May 30, 2021 09:34 PM
muddydawg
Engine Swaps
16
Oct 28, 2010 08:26 PM
jake00
General Automotive Discussion
Mar 14, 2009 01:26 PM
unclejesse67
Nov 22, 2007 04:13 PM
chuckdaddy
May 6, 2006 10:46 PM
