High Idle
Old May 15, 2012 | 12:14 PM
  #121
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by snakedoc
i was looking at the wiring and it looks like all that is needed is to put 12v to the #66 pin on the pcm.
is that what the Lblue wire we have tried doing?
Correct (light blue with yellow tracer).
When the PCM senses power from that wire, it conditionally enters a high idle state. The conditions are that a PTO 4R100 is present, the vehicle is in park and brake pedal is not being depressed (foot off brake).
Old May 15, 2012 | 12:19 PM
  #122
snakedoc's Avatar
snakedoc
i guess if that wire goes to pin 66 then there is no need to dig more that dose not work.
Old May 15, 2012 | 12:39 PM
  #123
grec-o-face's Avatar
grec-o-face
Originally Posted by Shake-N-Bake
... The conditions are that a PTO 4R100 is present... .
This allows for one more question; What tells the PCM that a "PTO 4R100" is present? The TSS? Can it be "tricked"?
(so maybe there are three questions...)
Old May 15, 2012 | 12:56 PM
  #124
Shake-N-Bake
Yes, the data comes via the TSS sensor but it can't be tricked because the sensor is physically sensing the PTO gear itself, which is different from a non-PTO unit. Here is an excerpt from a different discussion on another forum regarding the F150 Lightening trucks. The tooth count is what tells the PCM if a PTO is present.
Factory_Tech Factory_Tech is offline
Senior Member
Garage is empty, add now
Vehicle: 2005 Ford Mustang
A Lightning engine would twist a 4R70w in half, plan on getting a 4R100, and maybe getting the 4R100 built up a bit, at least a shift kit and maybe a complete rebuild. Also, make sure you get a Lightning version of the 4R100, there are aver 30 different models of 4R100 in any given year and only the L model will do, the other gas models aren't nearly as built as the L one. The L transmissions you could use are a 1F (1999) 1S (2000) 5X (2001 and up) do not use a 1J which was a Lightning model, it has the mechanical diode and there have been some issues with them.
The other gas models have either 3 or 4 gear planetary assemblies and the L models have 6 gear cast iron carriers, ther are other differences, but just know that not all 4R100s are created equal. If you're gonna go 4WD, you'll have to have one built, there is no gas model of 4R100 that uses the heavy parts except the PTO V-10 version and it has different linkage, case etc... which is no big deal, but it has different software for the 132 tooth PTO ring gear on the TSS, which is a very big deal. the standard TSS is programmed for a 34 tooth TSS and they just can't be swapped without very major canges in the software. Start with a Lightning model and change the output shaft and the extension housing, everything else is the same.
Hope this helps,
G
The entire thread can be found here:
Trans info needed - F150online Forums
Old May 15, 2012 | 01:12 PM
  #125
grec-o-face
Good Find! But I'm bummed...
Old May 15, 2012 | 01:23 PM
  #126
snakedoc's Avatar
snakedoc
no way to trick that.
i guess i can just do it like this https://www.ford-trucks.com/forums/5...e-control.html
Old May 15, 2012 | 01:29 PM
  #127
grec-o-face
Yeah, I've already assembled the set-up, just need to "cut" it in - I was hoping to avoid cutting into the factory TPS and IVS signals.
Old May 15, 2012 | 01:40 PM
  #128
Shake-N-Bake
no way to trick that....
Yep, We gave it a shot though...at least I learned a lot in the process.
To clarify....
The comment from Factory Tech that I posted earlier hints that the TSS for a PTO trans is programmed different compared to a non-PTO TSS. However, that is misleading. The TSS isn't programmed at all....it's merely a sensor. The programming is in the PCM. The TSS for a PTO trans is a different length (shorter) to accommodate the larger ring gear. 37mm vs 18.91 mm
So, this means the TSS and OSS is exactly the same sensor IF you have a non-PTO 4R100. If you have a PTO trans, then the OSS sensor is different from the TSS sensor. Make sure your parts counter guy gives you the correct part for your particular application.
Old May 15, 2012 | 01:47 PM
  #129
grec-o-face
To clarify....
I read the same thing. But, to add more unneeded info, there appears to be a resistance difference from the PTO TSS to the NON-PTO TSS. Hmmmm....
Old May 15, 2012 | 03:58 PM
  #130
snakedoc's Avatar
snakedoc
you might be on to something.
could it work?
4Wheelgreg
6.7L Power Stroke Diesel
Feb 26, 2018 07:06 AM
jp1096
Sep 29, 2014 07:03 PM
Midnight Ride
Jun 15, 2013 06:05 AM
kenny_barg
Mar 20, 2007 10:52 PM
nico963
Feb 21, 2007 10:43 AM
