High Idle
Old Apr 13, 2012 | 12:01 AM
  #106
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by kawcrasher
From what I recall it's the number of teeth on the PTO gear. Non-PTO trans have some gear there that acts as tone ring for something the PCM monitors, but it has way less teeth.
I couldn't the tooth count, but did find this on fleet fords site.
Great info. The sensor you are talking about is the TSS. That sensor on non-PTO models is 37mm long. PTO units have a sensor that is a little over 18mm in length....probably for the reason you describe. Sorta makes sense to me....that must be why I had to drive my wife's truck before the high idle would work after I reinstalled the PCM.
If the above is true...then a truck must have a PTO trans installed in order for the high idle feature to function. Just like you suggested earlier.
Old Apr 13, 2012 | 08:09 AM
  #107
grec-o-face's Avatar
grec-o-face
Originally Posted by grec-o-face
... I'll re-load my PCM with my SCT handheld, drive for a 1/2 mile or so, then try the switch. I think it's worth a try. To rule it out, at least.
No Luck... but I think we all new that was going to happen.
I think you're right... Bummer. Looks like there are only a few other options to obtain an 'idle-up' mode; Factory AIC unit, DIY AIC, or a custom tune/switch.
The thing that keeps me thinking is, what if someone was running a serpentine acc. that required 'high idle' to operate??
Old May 14, 2012 | 09:10 PM
  #108
snakedoc's Avatar
snakedoc
just to update it did not work on my truck.
i guess we need to find out what makes it think it has a PTO so it will work.
Old May 14, 2012 | 09:39 PM
  #109
Shake-N-Bake
It actually has to be a PTO transmission. The PCM can tell the difference. There appears to be a different tooth count or some way for the TSS to sense when a PTO trans is installed. That is why the truck must be driven before the high idle will work.
I tried a test. Two of my trucks are model year 2000. One with a PTO and other without. the high idle worked on the PTO truck while the other truck did not work. I swapped PCMs (thinking the programming was in the PCM). It didn't work. In fact, neither truck had fast idle. I drove about half a mile in the PTO truck and the fast idle began working again. I then drove around a little bit in the non-PTO truck (with the PCM from the truck with a previously working high idle switch) and the high idle would not work. I swapped the PCMs back to their original trucks and the only truck with high idle was the truck with the PTO trans.
This pretty much proves to me that the PCM can tell when a PTO trans is installed. I dont think there is any practical way to fool the PCM into thinking a PTO trans is installed.
Old May 14, 2012 | 10:16 PM
  #110
snakedoc's Avatar
snakedoc
i guess i will just have to just get it some other way.
Old May 14, 2012 | 10:40 PM
  #111
kawcrasher's Avatar
kawcrasher
Thanks for doing the work to prove a PTO trans is needed. We finally have proof the PCM recognizes the PTO transmission.
Tried to rep you, buy I'm in jail.
Old May 14, 2012 | 10:56 PM
  #112
snakedoc's Avatar
snakedoc
i will try my 2000 f450 truck and see if it will work. i do not think it has a pto trans
Old May 15, 2012 | 03:54 AM
  #113
Tugly's Avatar
Tugly
Originally Posted by Firefighter 1406
That is also what I found out also. It seems rare to find a pto tranny in a 250 unless it was ordered that way.
4X4 is a PTO tranny. Maybe this just works on 4X4s and other PTOs. My DP Tuner has the high idle tune, with the added feature of closing the EBPV to warm things up quicker.
Old May 15, 2012 | 08:44 AM
  #114
snakedoc's Avatar
snakedoc
my truck is a 4x4 and it dose not work?
Old May 15, 2012 | 09:16 AM
  #115
kawcrasher's Avatar
kawcrasher
Four wheel drive and PTO are not related.
Old May 15, 2012 | 10:51 AM
  #116
Shake-N-Bake
Originally Posted by Tugly
4X4 is a PTO tranny. Maybe this just works on 4X4s and other PTOs. ...
There are plenty of 4x4 transmissions without the PTO feature. From my observations, there are 4 different versions of 4R100 transmissions for the 7.3 engine.
  1. 2WD non-PTO
  2. 4WD non-PTO
  3. 2WD PTO
  4. 4WD PTO
However, some rebuild kits do offer an coast clutch upgrade where the PTO clutches are installed in a non-PTO transmission. This helps beef up the transmission for exhaust brake use or for other extreme applications. Unfortunately, this still does nothing for the high idle feature. My F450 has an 4R100 built by ATS with the PTO coast clutch upgrade but the transmission case is the standard type so the high idle feature will not work. On that truck I accomplish high idle via AIC or the PHP chip.
An easy way to spot a PTO trans is by looking for the access plate on the side of the case or the physical presence of the PTO drive itself.
Old May 15, 2012 | 10:58 AM
  #117
Shake-N-Bake
Matt,
Is your 4R100 a PTO model? If so, then you will need to reset the PCM before the high idle feature will work. I can walk you though that process if you would like. First you need to see if you have an access plate on the side of the case.
Old May 15, 2012 | 11:27 AM
  #118
snakedoc's Avatar
snakedoc
i will have to go look and see.
Old May 15, 2012 | 11:45 AM
  #119
snakedoc's Avatar
snakedoc
nope the 250 nor the 450 have the plate.
Old May 15, 2012 | 11:56 AM
  #120
snakedoc's Avatar
snakedoc
i was looking at the wiring and it looks like all that is needed is to put 12v to the #66 pin on the pcm.
is that what the Lblue wire we have tried doing?
