2016 Have a High Idle
Old Feb 22, 2018 | 10:40 AM
4Wheelgreg's Avatar
4Wheelgreg
Hey guys , I just picked up a 2016 F-450 do the 6.7's have a high idle or AIC controller like the only 7.3 .
I have not had a Ford Diesel in 18yrs , I am playing both sides of the manufactures ... I also have a 2016 GMC 3500 Duramax SRW and that truck has a High Idle control built into the truck controlled on the steering wheel .
Thanks
Old Feb 22, 2018 | 11:46 AM
dirthawg's Avatar
dirthawg
The 6.7l will idle up in cold weather. The colder the weather the higher the idle.
We can add our own SEIC with the use of a resistor and one upfitter switch.
https://www.ford-trucks.com/forums/1...-pictures.html
Old Feb 25, 2018 | 11:30 AM
Nipperdog's Avatar
Nipperdog
Hi: I set up the High idle Mod in my 2016 6.7. It is very easy to do if you are comfortable working with wiring. mine is hooked up to the #3 upfitter switch.
I used a Fixed 20,000 ohm Resistor between wht/brn, and Green to get 1200rpm when engaged.If you use the Potentiometer as shown in pic idle speed will be variable.
Hope this helps. BTW parking brake must be depressed and truck in park for it to work
https://www.fleet.ford.com/truckbbas...C-PTO_v1-0.pdf
Old Feb 26, 2018 | 07:06 AM
4Wheelgreg's Avatar
4Wheelgreg
Yeah I'm pretty handy ...
Thanks for the photo !
Iaff113
Mar 3, 2014 11:20 AM
Curt's05
Nov 24, 2013 08:03 PM
Midnight Ride
6.7L Power Stroke Diesel
Jun 15, 2013 06:05 AM
EXbowtieguy
Oct 31, 2011 09:50 AM
Acftmaintainer
Sep 9, 2010 06:39 PM
