Ok my front passenger window will roll down to a certain point and bog down to a certain point then will go all the way down. I took the door panel off and Theres no way of even heading anything. Has anybody else had this problem and what did you do to fix it
I have the exact same issue. When it’s cold out the window goes about half way and stops. When it’s been out in the hot weather for a few hours it seems to work fine. I generally hold the button down and it works but if I let it go on its own it stops. I took the door panel off and tried to put some grease on the gears as I moved the window up and down as I had visions of getting my finger chopped off in the gears. I hope somebody chimes in with a good idea as I have relegated myself to just deal with it. The fix would not be so difficult to figure out if I could only get access to the entire system behind the sheet metal.
Yup... My drivers side does it, the auto down stops now about half way. I "fixed" it for a while last summer with a bunch of WD-40 and such, but its back to its old ways.
