I just returned from Atlanta and had Powerstroke Specialists, do the EGR delete kit, oil cooler, coolant flush & fuel filters. Excellent job....Those guys are the best. Bill did recommend the coolant filter kit, but did not name any plave, in particular, to purchase it. Does anyone have any recommendations??
Ok. Id like to know why. Did i do something wrong with the above mentioned work, in some other peoples opinion? I am curious to hear more.....
No, I did not buy th EDAS...I did read about it, but they didnt even mention it. I bought this truck, used in Tn, and stopped in Atl. on the way home to SC. From all that I read, I thought that the EGR delete kit and new oil cooler kit, and coolant flush were the best preventative maintenance to hopefully avoid head gaskets, etc.........
Nothing wrong w/ the scope of your work. The shop probably did a decent job on the install. No reason to worry or second guess at this point IMO. Folks here have seen quite a bit on work from this shop and discussion about this shop, and the common belief is that there are better choices out there.
No reason getting into the details, except his videos have quite a few mistakes and as in all shops, it helps for the owner to know exactly what he needs before taking the truck in.
Since TruckNorris started the thread, you should probably start a new one if you have things to discuss on your truck.
