cold engine idle pickup
Old Dec 6, 2011 | 06:44 AM
Tugly's Avatar
Tugly
Maybe off-topic, but: I have the DP tuner with two tunes that put this to use. Warmup kicks up the throttle and activates the EBPV to get things warmed up faster. Decel activates the EBPV and uses the engine as a compression brake (also does some stuff in the auto transmission). I don't know what my EGTs do in the cold when in stock mode - I'll look into it.
Old Jan 4, 2012 | 09:48 PM
szotty's Avatar
szotty
hey did you ever find out what the problem was i found on the 18th that my ebvp butterfly valve in turbo outlet was off of the rod so check yours and see my retaining clip was on rod still just popped off
1996 f-250 7.3L
Feb 18, 2010 11:01 PM
clintl
Nov 14, 2006 05:57 PM
Baby-Semi
Dec 21, 2004 01:51 PM
SZMatters
May 25, 2004 11:38 PM
Kikwear
1978 - 1996 Big Bronco
Oct 6, 2003 06:13 PM
