Engine Idle too high
Old Dec 20, 2004 | 12:40 PM
Baby-Semi's Avatar
Baby-Semi
Exclamation Engine Idle too high
It's very cold here in Chicago. It's also my first winter with the Diesel. Ever since the cold weather the truck idle jumps up on cold start ups. If I tap the gas pedal the rpms go back to normal. This will happen a couple times and than it's OK. The truck runs great once warmed up. Is this normal?
Old Dec 20, 2004 | 12:46 PM
Pocket's Avatar
Pocket
Yes this is normal. Cold air package idles the truck up when engine oil and ambient temperature are cool enough. Also the Exhaust BackPressure Valve (EBPV) will engage and you'll hear a completely different exhaust note. All of this is to help the engine warm a little faster.
The higher idle is also supposed to help against wetstacking from idling too long. Normally you shouldn't have to let your truck idle up in the morning for much time at all. It was 15 degrees here this morning, and my truck sat idling for about 2 minutes before I pulled out. Just take it easy until the temp gauge starts rising closer to normal operating temps.
Old Dec 20, 2004 | 12:55 PM
Baby-Semi's Avatar
Baby-Semi
Thanks, so idle for about 2 minutes and than take it easy?
Old Dec 20, 2004 | 04:50 PM
Kwikkordead's Avatar
Kwikkordead
Yes, the deisel clatter will be louder when cold, so just be gentle on the throttle. But it certainly doesn't hurt it. It will warm up much faster if you are working the engine rather than sitting there idling.
Old Dec 21, 2004 | 01:51 PM
Baby-Semi's Avatar
Baby-Semi
Thanks you guys are great.
IHateCommieCars
Nov 29, 2014 06:24 PM
cappo
Jan 9, 2014 06:15 AM
StrokedRanchero
Jan 11, 2008 10:15 PM
Frobozz
Dec 24, 2004 01:00 PM
JoeBoost
Nov 26, 2002 10:12 AM
