High/inconsistent cold idle
<!-- / message -->
When your motor senses cold temps... it "boosts" the idle up from normal. Step on the brake or "go pedal" and it backs down to the lower idle. It is programmed this way for several reasons...
1) A diesel needs a hot glow plug to initiate the "start process".
2) A cold engine has a hard time compressing and burning diesel fuel.
3) A slow idle in cold weather (or what your engine believes is a cold motor) raises the engine RPM's to allow faster warm-ups and to prevent "cold soaking" of the injectors and cylinders. The hotter the motor the more efficient the process and the better performance you will get.
4) Idle will start out slow (normal) for a few seconds then bump up... well after oil pressure has been established.
____________
Next time the idle "bumps up"... touch the brake and it should come back down... if the motor senses it is still cold, the idle will go back up again.
Good luck,
Jeff
Thanks. Am familiar with reasons for a "warm-up" idle, but the engine is not reacting that way. First, it just started doing this - In May, not December when it was significantly colder. Next, the engine speed is not stable - alternates between 1100 and 1200 - not "hunting" but abruptly alternating. And lastly, it won't idle down with a touch of either the foot feed or brake. I end up driving away with the high idle and slamming the tranny around a bit as a result. It also screws up the downshifting strategy. I asked Ford to prove it was normal with some tech document, but they can't.
Oh, and now I have an idiot light telling me of an engine problem, so I guess I'll be going back to the dealer again (3 times in only 3300 miles).
I would get a PCM flash update to most current, or if it is most current they did not follow the "rule" book for proper procedure (must hook up batterycharger to ensure 100% power when programing and cycling the ignition.
Good luck,
Jeff
