cargo light question
Old Dec 1, 2011 | 09:06 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I want to install a cargo light on my project ('73 F100). Originally it didn't have one. I've located and bought a NOS light, switch and wiring harness.
Now for the question, does anybody have a picture of what the mounting hole in the roof looks like? And if you had the dimensions, that would be great.
Thanks in advance for any help.
Mike
Old Dec 1, 2011 | 09:17 AM
mark a.'s Avatar
mark a.
What year light did you get ? There are 2 different styles. The hole in the later ones, 78-79 are pretty crude, just hacked in. I don't know about the older ones.
Old Dec 1, 2011 | 10:51 AM
RunninD's Avatar
RunninD
Mike,
IIRC, from 67-77 (ya they're all the same again!!) The hole is rather keyhole shaped, wider at the Drivers side like 1" in diameter, and then a slot about 3/4" wide and two inches long, for about three inches total length. I remember someone on the forum having posted a photo, but not sure exactly who. Might have been Grinnergetter. I'm headed to the JY later today and will check to see if any of the trucks have one and getcha a photo.
Old Dec 1, 2011 | 11:14 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yup, they're different after mid-77, the change was at s/n Y60,001. I've got the early style.
Old Dec 1, 2011 | 11:16 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by RunninD
Mike,
IIRC, from 67-77 (ya they're all the same again!!) The hole is rather keyhole shaped, wider at the Drivers side like 1" in diameter, and then a slot about 3/4" wide and two inches long, for about three inches total length. I'm headed to the JY later today and will check to see if any of the trucks have one and getcha a photo.
Thanks, I appreciate any help I can get. I've been trying to find a picture of the mounting hole so I can come close to duplicating it. All I've been able to come up with are pictures of the light not the hole.
Old Dec 1, 2011 | 12:26 PM
Bill77F250's Avatar
Bill77F250
I got mine from a Junk Yard. I just took a piece of paper and traced the hole I took it from to transfer over to my truck.
Old Dec 1, 2011 | 08:32 PM
RunninD's Avatar
RunninD
None of the trucks in my local yard had the cargo light, sorry. I know I saw a photo in one of the build posts here not too long ago, but don't remember who's.
Old Dec 1, 2011 | 08:56 PM
grinnergetter's Avatar
grinnergetter
Hey, I can finally help this guy for a change. The left side is a bit bigger than it's supposed to be. I photographed the hole in the truck that I removed it from so this will be close.
Put the gasket on while you remove a little at a time. The light sits in there horizontally and it can fool you into thinking the hole should be bigger than it need to be. You get it when you do it.
Let me know if you want exact measurements.
Old Dec 1, 2011 | 09:04 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks grinner, I'll give that a shot, I'll let you know if I need the measurements.
Tried to rep you but it says I have to spread it around.
Mike
Old Dec 1, 2011 | 09:10 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That's the same problem I ran into. Around here there are only a handful of dents in the yards and none of them have the cargo light.
Thanks for checking.
reps sent
SCRebel
Nov 2, 2018 02:10 AM
Tees77f150
Feb 20, 2010 12:22 PM
1972-34ton
Aug 3, 2009 08:41 PM
sconut1
Jun 24, 2009 11:06 PM
n9lhm
Nov 14, 2005 11:17 PM
