need help with PATS!! 1998 Navi
Old Nov 28, 2011 | 02:41 PM
EagleKeeper1026's Avatar
EagleKeeper1026
my 98 gator wont start all of a sudden. the anti-theft light blinks and it clicks quickly. when i pull the ey out and unlock/lock the doors, the lights on the inside door flash a few times and then turn off. This happened to me a few years ago and I had to get a new key ($100+). It has a remote start that I have used maybe a couple times when i first bought it 4 years ago. the truck is garbage status and I don't want to put anymore money into it than I have to, but i do need it to haul stuff occasionally.
How can i yank this PATS out or disable it completely and avoid having to pay 100+ for another reprogramming? The key still has the sensor inside it, and the sensor on the truck side should still be in the steering column where it was previously.
would this happen if the sensor in the truck fell out of the steering column or something??
Old Nov 28, 2011 | 03:58 PM
Moto Mel's Avatar
Moto Mel
What brand and model of remote start do you have?
Old Nov 28, 2011 | 06:18 PM
EagleKeeper1026
I have no idea. I don't even know where to find it. I can't see anything under the dash that would indicate a remote start system
Old Nov 28, 2011 | 07:19 PM
Moto Mel's Avatar
Moto Mel
There should be a black plastic box near the fuse panel. It might say Cobra or Python on it. There may also be an OEM key hidden in the plastic shieding near the ignition lock that is often hidden there to eliminate the need for a bypass module in the system. If the hidden key somehow moved away from the PATs antenna the truck would not start. My thoughts are not Gospel as different installers have different methods for their installs.
Old Nov 28, 2011 | 08:54 PM
EagleKeeper1026
something similar to this happened about 3 years ago. there was a small sensor thing inside the steering column, but when i pulled the ignition out, it fell out and i couldn't get it to start so i had to call a locksmith to reprogram a new key. I can't afford another bill for this, so i just want the damn anti-theft removed for good. i assume there should be some way to cut some harnesses and install a relay or something. Or is it tied to the ECM?
How close does the sensor need to be to the antenna (which is located where?) to be within range?
Old Nov 28, 2011 | 09:42 PM
Moto Mel's Avatar
Moto Mel
If you remove the plastic surround you will see a small wire by the switch itself, that is the antenna. I believe it is programmed to the ECM and it might be cheaper to get another key. Look for the box I described, they are usually tucked up under the dash by the fuse box or behind the driver kick panel. you might be able to remove it without danage to the original wires and then you may be able to use an original key and the original remote entry key fob.
Old Dec 2, 2011 | 07:53 PM
kenny nunez's Avatar
kenny nunez
pats problem
I have a MK8 engine with a Cobra computer, I had the computer re flashed to kill the pats at a Mustang tuner shop.The engine is in a 67 FORD XL,it runs great. Kenny Nunez
Old Dec 2, 2011 | 09:44 PM
Moto Mel's Avatar
Moto Mel
Engine conversion
Do you have any pics of the car and some details on the conversion? I would like to see some, if you don't mind. That sounds like a nice conversion.
Old Dec 2, 2011 | 10:52 PM
kenny nunez
Mk8 engine
I am am going to get some pictures and information in a few days for you, I will need my son to help me as I am not too good sending this on the net, thanks for your input. Kenny Nunez
Old Dec 4, 2011 | 09:56 AM
EagleKeeper1026
If I just unplug the box, will i need to re-wire the harness?
Old Dec 4, 2011 | 01:03 PM
Moto Mel's Avatar
Moto Mel
Did you find an aftermarket alarm/remote start module? What brand and model?
Eightyfive Flareside
2004 - 2008 F150
Dec 7, 2016 10:26 AM
AndrewWV
Nov 17, 2011 01:30 PM
Scalemandave
1997 - 2003 F150
Jan 18, 2011 01:32 PM
autoworx
Jan 7, 2010 04:12 PM
dusty1
2004 - 2008 F150
May 25, 2004 08:37 AM
