My 1980 F350 has no spark. It was sitting in the garage for over 3 years. I decided to clean the garage today. Threw a battery in it and she fired right up Pulled it out of the garage and let in run in the driveway for about 20 min. I shut it down and went to cleaning the garage. 4 hours later I go to start it. Crank and crank and crank. I smell fuel, figure no spark. Pull a plug wire, jam a screw driver in it, and crank it over. NO SPArk. I have power to the coil and the coil is Hot. So I go get a coil. Put that in. Still. NO Spark
Another thing to check is the two connections between the dizzy and ign. module. Make sure you're getting good contact and the terminals are not all green.
Does the distributor have a large diameter cap, a vacuum advance and a plug with orange, black & purple wires?
Is there an aluminum ignition module about 5" square on the drivers side inner fender?
IIRC, the DS-II module for your truck should have a blue grommet where the wires come out of the housing. If you have power to the coil and the connections ChopTop was talking about are good then I side with Flareside - ignition module.
And, they can test them but you may have to find the right guy. The machine at the local O'Reillys doesn't show the right connections for that module - I know because I also have that one. The guy had to try several ways to connect the module before it started working.
Yes. That is the animal. It is a 400m truck, but I put a 429 in about 14 years ago.
Short of buying a new Ignition module, is there any tests that I can do to see if it is bad? No one around here tests them and I dont have any spares.
I just need the truck to drive back in the garage under its own power, I dont need perfection
Get a testlight or voltmeter. Put the neg probe on a good engine ground, and put the positive on the negative of the coil. Crank the engine. The testlight should blink or the voltmeter should jump up and down, telling you the module is turning the coil on and off.
If it's not blinking, I would take the dist cap off and make sure the rotor is turning when the engine is cranked. If it's turning, I would unplug and plug back in the connectors to the distributor. If that doesn't work, I would hunt around or go buy another module and try it. If that doesn't work, the pickup inside the dist is the only thing left.
P.S. You should have 12v on the red wire to the module while cranking or the keyswitch is in run.
Well. I just went out to work on the truck. Figured before i would do anything, i would try to start it. It coughed So i kept trying but then nothing. So I put the test light on the neg side of the coil to check for pulse. Wasnt blinking but then the truck fired w the test light on the neg post of the coil. And while running the light was on. Go figure. Took test light off, and was picking up tools and the truck stalled But it fired right backup with no help. I guess when I finally go to dig into this project, I will have to find the problem
That's probably because it was blinking on and off so fast, you couldn't see that it was turning on and off. That's how it works though, just like the old points systems worked. They put 12v through a resistance wire to the coil + all the time the key is on, and then they ground and unground the negative of the coil to make the coil spark through the high voltage wire in the center of the coil. The module just does the same thing electronically.
That's because solid state devices can "sink", meaning take to ground, a lot more current than they can "source", meaning supply current.
Had a similar conversation with a Nissan service manager recently when our new (325 miles) Murano decided the world was too dark and turned the lights on in the middle of the night. Where everything used to be grounded permanently in a vehicle and we supplied power to them via a switch, things are now permanently supplied power and the vehicle's electronics complete the circuit by sinking the current. So, it is easy to see how a glitch can bring the lights on, even when the ignition is off and the light switch is in the OFF position.
